1GB or 10GB
dwchan69
I am trying to determine which network approach would be best to maximum the network performance on a new FreeNAS server I am building. The end points would consist of either 1GB or 10GB clients (e.g. desktop with a single 1Gb NIC and VMware host with either multi 1Gb NIC or a single 10Gb NIC). I have both a 1Gb and 10Gb copper (Not Fabric) switches available to use. From a simplicity stand point, I can just used 1Gb through out the infrastructure, even on the VMware host, but worry about the overall throughput a single Gb NIC can maintain around FreeNAS iSCSI or NFS. In addition, I am not sure how effective would LAG be using LACP on FreeNAS. In short,
1. Has much testing been doing on FreeNAS using a 10Gb back end (10G NIC on FreeNAS, to 10G switch to both 1G/10G endpoints) to facilitate both 1Gb and 10G clients?
2. Or would it be just as easy to used all 1Gb infrastructure and configure LACP on FreeNAS, the 10G switch, and VMware host to increase performance as the environment grow?
3. Or is it possible to have both 1Gb and 10G interfaces on the FreeNAS, each on a difference VLANs/subnets to service both 1G and 10G clients that way?
Thanks
1GB is not 1Gb. I don't know anything about this mythical 1GB network or 10GB network. But higher numbers are always better, right?
toadman
Best practices say you're going to want multiple nics on any server. I'm abstracting the topology because I don't know what configuration you're trying to put in place. But if redundancy is important to you you'd never have a server with a single 10G nic (VMware or FreeNAS). So assuming redundancy is important I'd point you to multiple 1G nics.
Answer to your questions:
(1) I don't know. There are people here using 10G, so that works. I don't see why a combo of 1G and 10G wouldn't work.
(2) Your planned topology has a lot to do with the answer to this question. So it's hard to say. In general, yes, you can scale. To a point. 10G is gonna work a lot better than LACP on 1G though.
(3) Yes, should be "easy." My FreeNAS services several subnets/VLANs like this. It'd all 1G though, no 10G. You can place vlans on whatever adapter you choose.
