12.0-U6 CPU temperature reporting bug?
Samuel Tai
Since I upgraded from 12.0-U5.1, CPU temperature reporting under Reporting->CPU no longer works:
But I do get CPU temperatures in the main Dashboard:
Anybody else run across this?
Samuel Tai
ErKr
Yep, same issue with an old Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz
K.J
Also here the same problem with version: TrueNAS-12.0-U6
birdseed
Thank you! I was searching for this issue, I have it on 2 different systems. It looks to me like the y-axis scale only goes to 1 degree C instead of 100?
revengineer
Can this be fixed by the user editing a file? It seems like ixsystems has gone silent on further CORE releases.
