f00b4r00
 - Jan 5, 2020
I've setup pull replication on a "slave" FreeNAS running 11.3-U2, that pulls from a master running 11.2-U8.
The setup is as follows:
If I try to run this task with these settings, it will fail with:
If I uncheck "Compress", then the replication works. I'm a bit surprised because zfs on both sides support
Also, while I'm there: the web interface on 11.3 feels much much more sluggish on my browser (tested in Safari and Brave) that 11.2. To the point that there is a significant (can be measured in seconds) lag when scrolling around. This affects in particular setting pages like the setting page of the Replication Task. Trying to open the Task Manager literally hangs the browser window.
HTH
Transport: SSH+NETCAT
Netcat active side: LOCAL
Recursive: true
Properties: true
Allow large blocks: true
Compress: true
* Replication "TEST" failed: Traceback (most recent call last): File "/tmp/zettarepl--transport--ssh_netcat_helper.py--bbd790a8e68026f3fab64fc323484eda", line 104, in flags.add(libzfs.SendFlag.COMPRESS) File "/usr/local/lib/python3.6/enum.py", line 326, in __getattr__ raise AttributeError(name) from None AttributeError: COMPRESS failed to read from stream..
-c: is this a bug?Also, while I'm there: the web interface on 11.3 feels much much more sluggish on my browser (tested in Safari and Brave) that 11.2. To the point that there is a significant (can be measured in seconds) lag when scrolling around. This affects in particular setting pages like the setting page of the Replication Task. Trying to open the Task Manager literally hangs the browser window.
HTH
