SerialMonkey
- Mar 4, 2020
I am attempting to join our Windows AD with fresh install of 11.3-U1.
I am getting the following error:
Failed to validate bind credentials: [EFAULT] [Errno 8] hostname nor servname provided, or not known
If I intentionally enter a bad password, I get the following error:
Failed to validate bind credentials: [EFAULT] kinit for domain [DOMAIN.COM] with password failed: kinit: Password incorrect
Which indicates its able to find, connect to the domain DC and validate the credentials provided.
I manually enabled Samba and running the following from CLI:
#net -k -d 5 ads join
Output;
Host is not configured as a member server.
Invalid configuration. Exiting....
Failed to join domain: This operation is only allowed for the PDC of the domain.
return code = -1
Updated the /usr/local/etc/smb4.conf as follows:
server role = member
Restarted samba_server:
# service samba_server restart
Reran
Output:
realm must be set in in /usr/local/etc/smb4.conf for ADS join to succeed.
Failed to join domain: The parameter is incorrect.
return code = -1
Once again updated /usr/local/etc/smb4.conf
realm = domain.com
Restart samba_service and ran ads join
This time, the AD join completed successfully. However, the AD join via the Web GUI continues to fail.
Why am I able to join the domain using Samba, but the AD module fails?
Fresh install with 11.2-U8 joins the domain without issue.
Curtis
Output;
return code = -1
Reran
Output:
return code = -1
realm = domain.com
Curtis
