Not sure what is going on but I created a 100G zvol on a 240G SSD. After creation I installed Windows Server 2008 r2 in a VM using the zvol as a disk. After installation the GUI showed a warning that the SSD was at 94% of capacity. I am running FreeNAS 11.1-U1
Anyone have any idea what is going on?
The output of zfs get all is below:
NAME PROPERTY VALUE SOURCE vms/windows2008 type volume - vms/windows2008 creation Mon Feb 5 0:02 2018 - vms/windows2008 used 202G - vms/windows2008 available 10.7G - vms/windows2008 referenced 202G - vms/windows2008 compressratio 1.02x - vms/windows2008 reservation none default vms/windows2008 volsize 100G local vms/windows2008 volblocksize 512 - vms/windows2008 checksum on default vms/windows2008 compression lz4 inherited from vms vms/windows2008 readonly off default vms/windows2008 copies 1 default vms/windows2008 refreservation 150G local vms/windows2008 primarycache all default vms/windows2008 secondarycache all default vms/windows2008 usedbysnapshots 0 - vms/windows2008 usedbydataset 202G - vms/windows2008 usedbychildren 0 - vms/windows2008 usedbyrefreservation 0 - vms/windows2008 logbias latency default vms/windows2008 dedup off inherited from vms vms/windows2008 mlslabel - vms/windows2008 sync standard default vms/windows2008 refcompressratio 1.02x - vms/windows2008 written 202G - vms/windows2008 logicalused 27.5G - vms/windows2008 logicalreferenced 27.5G - vms/windows2008 volmode default default vms/windows2008 snapshot_limit none default vms/windows2008 snapshot_count none default vms/windows2008 redundant_metadata all default vms/windows2008 org.freenas:description local
