10 Gig Nic and Internal Nic
Rickinfl
I have FreeNAS 11. I have an onboard NIC and a dual 10 Gig NIC installed plugged into my Cisco 10 Gig ports configured as Trunks on a VLAN.
I created a VLAN and a Lagg0 attached both of the 10 Gig ports to it. But can't seem to get it to work. When I try and assign IP it keeps telling me "The network 10.XXX.XX.0/24 is already in use by another NIC"
I'm trying to use the 10 Gig ports and load balance them. The internal NIC I was trying to use just for Management. I'm using the GUI so not sure where to start and make it simple enough to setup.
Not sure how to attach the VLAN to the Lagg0 either.
What I would like is the the Internal NIC to be 10.XXX.XX.100/24 and the Lagg0 to be 10.XXX.XX.99/24.
Any help would be appreciated.
Thanks,
Rick
Rickinfl
Ok. I'll drop the Internal Nic and use that IP address on the lagg0. How do I set that up with a VLAN?
