安装nextcloud插件报错,help me
tangjie
truenas安装nextcloud到90%是总报错,不知道什么原因。
Error: MYCloud had a failure Exception: RuntimeError Message: Last 10 lines: + + writing new private key to '/usr/local/etc/letsencrypt/live/truenas/server.key' ----- Signature ok subject=O = TrueNAS (Nextcloud), CN = localhost Getting CA Private Key mysqladmin: [Warning] Using a password on the command line interface can be insecure. Warning: Since password will be sent to server in plain text, use ssl connection to ensure password safety. mysql: [Warning] Using a password on the command line interface can be insecure. Partial plugin destroyed
ryuukonnhou
me too.
ERROR:
nextcloud had a failure Exception: RuntimeError Message: Last 10 lines: ----- Signature ok subject=O = TrueNAS (Nextcloud), CN = localhost Getting CA Private Key mysqladmin: [Warning] Using a password on the command line interface can be insecure. Warning: Since password will be sent to server in plain text, use ssl connection to ensure password safety. mysql: [Warning] Using a password on the command line interface can be insecure. Partial plugin destroyed.
ryuukonnhou
我的是Truenas12.0 u8,全新安装nextcloud ,也是90%块成功了就报这个错。
leeosx
......不好折腾。。太累了。
ryuukonnhou
我通过新建监狱,手动安装软件已经解决了,不能通过官方的插件安装。
