hooti3
- Feb 10, 2020
Hi All,
I thought I'd reach out for some help in getting my zPool back online.
One of my disks died in my Raid-z1 (5 disk pool).
I've looked online to try and get some assistance, but rather than make a mistake and possibly lose my data (which may already be the case), I thought I would reach out for some help.
I've added in another blank disk in hopes of bringing the volume and zPool back online, but haven't had any success.
The drive is a blank 3TB WD Red I had lying around.
The failed disk is visible when running the above command, but not visible in the GUI to offline.
Hardware specs:
- Asus P10S-I
- G4560
- 16GB Non-ECC Memory
- 5 HDD (WD Red 4TB each )
- 1 Intel SSD for OS.
I've never had to replace a drive before on a FreeNAS, so really just wanting to get some guidance on it.
Additional checks from my Reddit post - https://www.reddit.com/r/freenas/comments/f13ch2/zpool_unavailable_unknown_drive_failure/
As you can see there is no ability to edit the pool status or check the drives.
https://ibb.co/YNVL9DD
I've attempted a zpool import via the shell and received this error message:
https://ibb.co/h9mtDTW
[root@freenas ~]# zpool import
pool: Storage
state: DEGRADED
status: One or more devices are missing from the system.
action: The pool can be imported despite missing or damaged devices. The
fault tolerance of the pool may be compromised if imported.
see: http://illumos.org/msg/ZFS-8000-2Q
Storage DEGRADED
raidz1-0 DEGRADED
gptid/93df7155-0be3-11e8-9668-38d547757201 ONLINE
gptid/94a17197-0be3-11e8-9668-38d547757201 ONLINE
ada3p2 ONLINE
12885366225365287864 UNAVAIL cannot open
gptid/976a0085-0be3-11e8-9668-38d547757201 ONLINE I've looked online to try and get some assistance, but rather than make a mistake and possibly lose my data (which may already be the case), I thought I would reach out for some help.
Hardware specs:
- Asus P10S-I
- G4560
