pattawongse
- Oct 18, 2012
my build
-INTEL XEON E1230 V2 3.30GHz (1155)
-INTEL M/B SERVER S1200BTLR (1155)
-60Gb SSD
-8 Gb x4 ECC RAM
-WD RED 3 Tb x 20
-Dell H310 OEM x2
running FreeBSD 8.3-RELEASE-p7 (FREENAS.amd64) #1 r249203M
set-up in 8 + 8 + 4
ZFS_1 : 8x3Tb (Raid-Z1) [H310 JBOD][mfisyspd0-7]
ZFS_2 : 8x3Tb (Raid-Z1) [H310 JBOD][mfisyspd8-15]
ZFS_3 : 4x3Tb (Raid-Z1) [On-Board Controller][ada0,ada1,ada2,ada4]
it run without any problem for 4 month
yesterday i found ZFS_1 pool lost
first i check with zpool status and found only 2 pool(ZFS_1 missing)
after that i run zpool import
so i run addition test
mfiutil -u 0 show drives
it seem everything seem fine
missing drive are
so i shutdown and remove ZFS_2 (H310 raid card and 8 Hdd[mfisyspd8-15])
to reduce confused
when booting up found some error msg
so i ran dmesg
getting these msg http://pastebin.com/xexX9YaJ
zpool status
zpool import
gpart show
gpart list : http://pastebin.com/YYjdHGVs
in gpart show , gpart list it not showing mfisyspd0,mfisyspd1
i tried zpool import ZFS_1 with zpool import ZFS_1 and zpool import -F ZFS_1
getting same error
i searching for fix issue and found someone suggest
i plug-out mfisyspd0 <WDC WD30EFRX-68A 0A80 serial=WD-WCC1T0427074>[ada0] and new WD RED 3Tb[ada1] into another PC
booting with freenas usb to ran
recoverdisk -w worklist /dev/ada0 /dev/ada1
after ran for something like 2 minute got these error
anyone got idea for rescue my server please
PS.1.already tried to swap raid card,cable anything and still getting same error(issue cause from 2 hdd for sure)
2.sorry for my bad english
-60Gb SSD
-8 Gb x4 ECC RAM
-WD RED 3 Tb x 20
-Dell H310 OEM x2
set-up in 8 + 8 + 4
pool: ZFS_1
state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
devices and try again.
see: http://www.sun.com/msg/ZFS-8000-3C
ZFS_1 UNAVAIL insufficient replicas
raidz1-0 UNAVAIL insufficient replicas
18446742974716428848 UNAVAIL cannot open
14795978872498413746 UNAVAIL cannot open
gptid/213f572c-a71c-11e2-99f5-001e6777ba59 ONLINE
gptid/21850ac3-a71c-11e2-99f5-001e6777ba59 ONLINE
gptid/21c6dcab-a71c-11e2-99f5-001e6777ba59 ONLINE
gptid/2207cba7-a71c-11e2-99f5-001e6777ba59 ONLINE
gptid/2246ff52-a71c-11e2-99f5-001e6777ba59 ONLINE
gptid/22877842-a71c-11e2-99f5-001e6777ba59 ONLINEso i run addition test
mfi0 Physical Drives: 0 ( 2794G) JBOD <WDC WD30EFRX-68A 0A80 serial=WD-WCC1T0427074> SATA S0 1 ( 2794G) JBOD <WDC WD30EFRX-68A 0A80 serial=WD-WCC1T0517661> SATA S1 2 ( 2794G) JBOD <WDC WD30EFRX-68A 0A80 serial=WD-WCC1T0517687> SATA S2 3 ( 2794G) JBOD <WDC WD30EFRX-68A 0A80 serial=WD-WCC1T0517618> SATA S3 4 ( 2794G) JBOD <WDC WD30EFRX-68A 0A80 serial=WD-WCC1T0512595> SATA S4 5 ( 2794G) JBOD <WDC WD30EFRX-68A 0A80 serial=WD-WCC1T0512590> SATA S5 6 ( 2794G) JBOD <WDC WD30EFRX-68A 0A80 serial=WD-WCC1T0517637> SATA S6 7 ( 2794G) JBOD <WDC WD30EFRX-68A 0A80 serial=WD-WCC1T0326719> SATA S7
missing drive are
0 ( 2794G) JBOD <WDC WD30EFRX-68A 0A80 serial=WD-WCC1T0427074> SATA S0[mfisyspd0] 1 ( 2794G) JBOD <WDC WD30EFRX-68A 0A80 serial=WD-WCC1T0517661> SATA S1[mfisyspd1]
to reduce confused
so i ran dmesg
zpool status
pool: ZFS_3
state: ONLINE
scan: scrub repaired 0 in 2h5m with 0 errors on Sun Jun 2 02:05:31 2013
NAME STATE READ WRITE CKSUM
ZFS_3 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/6044c5e2-a71c-11e2-99f5-001e6777ba59 ONLINE 0 0 0
gptid/60a008a4-a71c-11e2-99f5-001e6777ba59 ONLINE 0 0 0
gptid/60fe0c4e-a71c-11e2-99f5-001e6777ba59 ONLINE 0 0 0
gptid/61638bfc-a71c-11e2-99f5-001e6777ba59 ONLINE 0 0 0zpool import
pool: ZFS_1
state: UNAVAIL
gptid/22877842-a71c-11e2-99f5-001e6777ba59 ONLINEgpart show
=> 34 5860533101 mfisyspd2 GPT (2.7T) [CORRUPT]
34 94 - free - (47k)
128 4194304 1 freebsd-swap (2.0G)
4194432 5856338703 2 freebsd-zfs (2.7T)
=> 34 5860533101 mfisyspd3 GPT (2.7T) [CORRUPT]
=> 34 5860533101 mfisyspd4 GPT (2.7T) [CORRUPT]
=> 34 5860533101 mfisyspd5 GPT (2.7T) [CORRUPT]
=> 34 5860533101 mfisyspd6 GPT (2.7T) [CORRUPT]
=> 34 5860533101 mfisyspd7 GPT (2.7T) [CORRUPT]
=> 34 5860533101 ada0 GPT (2.7T)
4194432 5856338696 2 freebsd-zfs (2.7T)
5860533128 7 - free - (3.5k)
=> 34 5860533101 ada1 GPT (2.7T)
=> 34 5860533101 ada2 GPT (2.7T)
=> 63 234441585 ada3 MBR (111G)
63 1930257 1 freebsd [active] (942M)
1930320 63 - free - (31k)
1930383 1930257 2 freebsd (942M)
3860640 3024 3 freebsd (1.5M)
3863664 41328 4 freebsd (20M)
3904992 230536656 - free - (110G)
=> 34 5860533101 ada4 GPT (2.7T)
=> 0 1930257 ada3s1 BSD (942M)
0 16 - free - (8.0k)
16 1930241 1 !0 (942M)
getting same error
cannot import 'ZFS_1': no such pool or dataset
Destroy and re-create the pool from
a backup source.i searching for fix issue and found someone suggest
GPT rejected -- may not be recoverable. corrupt or invalid GPT detected.
