ZFS is full and system is now unuseable
dovaka
for some reason or another my zfs pool is entirely full and no matter what i do i cant seem to get the system to work well enough to purge out some data. ive tried using cifs, afp, ftp and even command line to remove files but keep running into various issues with each. im not really sure what to try next.
Do some searching in the forums. There is a command that you have to use to wipe out a file, but I forget what it is. Unfortunately I don't have the time to search for you right now. Sorry.
gpsguy
Active Member
Look at message #3 in a thread named: Disk full - can't delete any files
Sent from my phone
dovaka
actually even when I try it on a file I get this
[root@studionas ~]# echo > /mnt/Main_Storage/Movies/9.avi
bash: /mnt/Main_Storage/Movies/9.avi: No space left on device
[root@studionas ~]#
mpfusion
[root@studionas ~]#
This actually write a newline to the file. If your filesystem is THAT full that it doesn't even take a single byte you can try to wipe the file instead of writing a newline to it:
: > /mnt/Main_Storage/Movies/9.avi
dovaka
same result
[root@studionas ~]# : > /mnt/Main_Storage/Movies/9.avi
[root@studionas ~]#
dovaka
i had snap shots which is what i believe caused the disk to fill up and the retention time is something ridiculous so they arent expiring anytime soon
solarisguy
Step 2. execute zfs list -H -o name -t snapshot
and start deleting from that list manually (start with oldest one) zfs destroy snapshot_name
dovaka
i ran that command and it appears to be doing something as all the drives are showing activity but its been there for over an hour without posting anything
dovaka
ok it justspit out a bunch of stuff like this
Main_Storage/bil@auto-20140513.0847-10y
Main_Storage/bil@auto-20140513.1044-10y
Main_Storage/bil@auto-20140513.1240-10y
Main_Storage/bil@auto-20140513.1436-10y
Main_Storage/bil@auto-20140513.1639-10y
Main_Storage/bil@auto-20140513.1846-10y
Main_Storage/bil@auto-20140513.2051-10y
Main_Storage/bil@auto-20140513.2255-10y
Main_Storage/bil@auto-20140514.0059-10y
Main_Storage/bil@auto-20140514.0306-10y
Main_Storage/bil@auto-20140514.0509-10y
Main_Storage/bil@auto-20140514.0706-10y
[root@studionas ~]#
dovaka
which then returns this
[root@studionas ~]# : > /mnt/Main_Storage/bil@auto-20140512.0706-10y
bash: /mnt/Main_Storage/bil@auto-20140512.0706-10y: No space left on device
[root@studionas ~]#
