Greetings All.
I am using Freenas 8.2.0 x64 w/8GB of RAM and an 11 x 2TB RaidZ1, and had a drive (ADA5) go south and went through the GUI replacement method using the same drive location:
1. Take drive "Offline"
2. Shut down Freenas. Replace bad drive with known good one
3. Bring Freenas backup. Select "Replace" and pick ada5 in the pulldown.
4. Zpool begins to resliver. Everything is looking good.
5. Resilver completed, but still showing permanent errors. No prob, I'll get to that since it seems like all the data is still good.
6. Try to "Detatch" the bad drive, and get told it was successfully detached.
However, the pool still shows as degraded, and the GUI still shows the bad drive as being UNAVAIL. Odd. So maybe it's a GUI issue and I go to a shell and do ye ol' zpool status (latest shown, but it's been like this for a good week or so despite multiple scrubs and such):
Okay, so let's go ahead and detach from here, assuming it's a GUI issue:
[root@freenas] ~# zpool detach MEDIA 2601964793004239810
cannot detach 2601964793004239810: no valid replicas
[root@freenas] ~# zpool detach MEDIA /dev/gptid/f758f793-e1bd-11e1-a00e-001a4d4cb59b
cannot detach /dev/gptid/f758f793-e1bd-11e1-a00e-001a4d4cb59b: no valid replicas
So, this has continued for over a week with various attempts to try to get things resolved. It appears that I cannot detach the old drive, regardless of what I try, although by all accounts the new drive is online and working, and I have no data corruption issues. Based upon recommendations in the forums, all the following have been attempted, plus several other miscellaneous attempts to make some progress:
1. Doing an export then import zpool.
2. Booting with the alpha Freenas 8.3 and doing an import, scrub and then detach. Stil getting no valid replicas.
3. Replace ada5 with yet another new drive, allow it to resilver. This only results in me having two drives that are UNAVAIL and neither can be detached.
4. Put the old drive back in, and resilver again.
Here is all the usual additional info that is asked for on here:
Thoughts on what approach I can take to get this resolved, short of toasting the entire pool and re-loading 10+ TB of data????
[root@freenas] ~# zpool status -v | more
pool: MEDIA
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://www.sun.com/msg/ZFS-8000-8A
scrub: resilver completed after 22h19m with 448836 errors on Thu Sep 20 23:20:05 2012
NAME STATE READ WRITE CKSUM
MEDIA DEGRADED 0 0 438K
raidz1 DEGRADED 0 0 877K
gptid/f40f30a3-e1bd-11e1-a00e-001a4d4cb59b ONLINE 0 0 0
gptid/f4a0911a-e1bd-11e1-a00e-001a4d4cb59b ONLINE 0 0 0
gptid/f55231c6-e1bd-11e1-a00e-001a4d4cb59b ONLINE 0 0 0
gptid/f6048bd8-e1bd-11e1-a00e-001a4d4cb59b ONLINE 0 0 0
gptid/f6d35c5c-e1bd-11e1-a00e-001a4d4cb59b ONLINE 0 0 0
replacing DEGRADED 0 0 0
2601964793004239810 UNAVAIL 0 0 0 was /dev/gptid/f758f793-e1bd-11e1-a00e-001a4d4cb59b
gptid/79561e7f-ff9e-11e1-9a9a-001a4d4cb59b ONLINE 0 0 0 1.00T resilvered
gptid/f826f656-e1bd-11e1-a00e-001a4d4cb59b ONLINE 0 0 0
gptid/f8c889bc-e1bd-11e1-a00e-001a4d4cb59b ONLINE 0 0 0
gptid/f95bd681-e1bd-11e1-a00e-001a4d4cb59b ONLINE 0 0 0 7.96M resilvered
gptid/fa070a8e-e1bd-11e1-a00e-001a4d4cb59b ONLINE 0 0 0
gptid/fa93a8d3-e1bd-11e1-a00e-001a4d4cb59b ONLINE 0 0 0
MEDIA:<0x6114>
MEDIA:<0x6125>
MEDIA:<0x61ac>
MEDIA:<0x61bd>
MEDIA:<0x60e0>
MEDIA:<0x60ec>
MEDIA:<0x60fb>
MEDIA:<0x60fd>
[root@freenas] ~# gpart show
=> 63 7864227 da0 MBR (3.8G)
63 1930257 1 freebsd [active] (943M)
1930320 63 - free - (32K)
1930383 1930257 2 freebsd (943M)
3860640 3024 3 freebsd (1.5M)
3863664 41328 4 freebsd (20M)
3904992 3959298 - free - (1.9G)
=> 0 1930257 da0s1 BSD (943M)
0 16 - free - (8.0K)
16 1930241 1 !0 (943M)
=> 34 3907029101 ada0 GPT (1.8T)
34 94 - free - (47K)
128 4194304 1 freebsd-swap (2.0G)
4194432 3902834703 2 freebsd-zfs (1.8T)
=> 34 3907029101 ada1 GPT (1.8T)
=> 34 3907029101 ada2 GPT (1.8T)
=> 34 3907029101 ada3 GPT (1.8T)
=> 34 3907029101 ada4 GPT (1.8T)
=> 34 3907029101 ada5 GPT (1.8T)
=> 34 3907029101 ada6 GPT (1.8T)
=> 34 3907029101 ada7 GPT (1.8T)
=> 34 3907029101 ada8 GPT (1.8T)
=> 34 3907029101 ada9 GPT (1.8T)
=> 34 3907029101 ada10 GPT (1.8T)
[root@freenas] ~# glabel status
Name Status Components
ufs/FreeNASs3 N/A da0s3
ufs/FreeNASs4 N/A da0s4
ufs/FreeNASs1a N/A da0s1a
gptid/f40f30a3-e1bd-11e1-a00e-001a4d4cb59b N/A ada0p2
gptid/f4a0911a-e1bd-11e1-a00e-001a4d4cb59b N/A ada1p2
gptid/f55231c6-e1bd-11e1-a00e-001a4d4cb59b N/A ada2p2
gptid/f6048bd8-e1bd-11e1-a00e-001a4d4cb59b N/A ada3p2
gptid/f6d35c5c-e1bd-11e1-a00e-001a4d4cb59b N/A ada4p2
gptid/79561e7f-ff9e-11e1-9a9a-001a4d4cb59b N/A ada5p2
gptid/f826f656-e1bd-11e1-a00e-001a4d4cb59b N/A ada6p2
gptid/f8c889bc-e1bd-11e1-a00e-001a4d4cb59b N/A ada7p2
gptid/f95bd681-e1bd-11e1-a00e-001a4d4cb59b N/A ada8p2
gptid/fa070a8e-e1bd-11e1-a00e-001a4d4cb59b N/A ada9p2
gptid/fa93a8d3-e1bd-11e1-a00e-001a4d4cb59b N/A ada10p2
gptid/79308105-ff9e-11e1-9a9a-001a4d4cb59b N/A ada5p1
[root@freenas] ~# camcontrol devlist <SAMSUNG HD204UI 1AQ10001> at scbus0 target 0 lun 0 (pass0,ada0) <Hitachi HDS5C3020ALA632 ML6OA180> at scbus0 target 1 lun 0 (pass1,ada1) <Hitachi HDS5C3020ALA632 ML6OA580> at scbus0 target 2 lun 0 (pass2,ada2) <SAMSUNG HD204UI 1AQ10001> at scbus0 target 3 lun 0 (pass3,ada3) <WDC WD20EARX-00PASB0 51.0AB51> at scbus0 target 4 lun 0 (pass4,ada4) <Port Multiplier 37261095 1706> at scbus0 target 15 lun 0 (pass5,pmp0) <WDC WD20EARS-00J2GB0 80.00A80> at scbus1 target 0 lun 0 (pass6,ada5) <WDC WD20EARS-00MVWB0 51.0AB51> at scbus3 target 0 lun 0 (pass7,ada6) <SAMSUNG HD204UI 1AQ10001> at scbus4 target 0 lun 0 (pass8,ada7) <Hitachi HDS5C3020ALA632 ML6OA580> at scbus6 target 0 lun 0 (pass9,ada8) <SAMSUNG HD204UI 1AQ10001> at scbus7 target 0 lun 0 (pass10,ada9) <Hitachi HDS5C3020ALA632 ML6OA5C0> at scbus8 target 0 lun 0 (pass11,ada10) <Generic Card-Reader 1.03> at scbus9 target 0 lun 0 (pass12,da0)
