will '-c NNNNN' make badblocks test 10 TB disk faster ?
guermantes
It is customary on large new disks to test them with badblocks -b 4096 -wsv /dev/adaX (besides the SMART tests). I saw a thread on stackexchange where the user also specified -c 131072 in order to test 128 blocks at the same time. I can't remember seeing the -c option being mentioned here on the forum, although I would guess it speeds up the test. Is it not relevant for the execution speed of the test?
Chris Moore
guermantes
Chris Moore
are you helping him port the script to FreeBSD?
I already downloaded it, so I will be looking into the script and doing some testing. I have work and school, but I will try to make time for it.
It would be a great addition to the FreeNAS GUI.
I might be able to get it working on FreeNAS, but I don't expect it to be included in the GUI. It would probably be like these other scripts:
Github repository for FreeNAS scripts, including disk burnin
https://forums.freenas.org/index.ph...for-freenas-scripts-including-disk-burnin.28/
