Poetart
- Jan 4, 2018
TL;DR: iSCSI drops connection and refuses to connect again without a hard reboot of the box. Also, wondering if I have my box setup correctly or what I can do to make it better. Advice welcome
Current Setup:
CPU: Intel i5-4690K 3.50GHz
MoBo: ASUS Z97-A
RAM: 16GB Avexir Core Series DDR3 1600 \(PC3 12800\
Case: Rosewill 4U Server Chassis \(RSV-L4500\)
SAS Card (x2): SAS9211-8I 8PORT Int 6GB Sata+sas
Single Flash Drive (Microcenter branded) 8GB
Samsung 840 EVO 256GB: Not in use
Samsung 850 EVO 1TB: Not in use
10GB NIC with Fiber SFP
Single Mode fiber cable
Thermal are pretty stable and CPU has yet to ever hit even 75% load. Moved 9TB of data to the thing and it never got above 35c
[Reporting Snapshot]
One of the WD 3TB's failed when I was working on setting this up but it is under warranty so I am waiting on getting that back before I so anything with the 3TB drives.
-------------------------HDD---------------------------
Totals:
6 x 2TB
3 x 3TB
3 x 4TB
3 x 5TB
5 x SAMSUNG F3EG HD203WI 2TB 5400 RPM 32MB Cache SATA 3.0Gb/s 3.5"
1 x Toshiba X300 5TB 7200 RPM 128MB Cache SATA 6.0Gb/s
2 x WD Black 3TB 7200 RPM SATA 6Gb/s 64MB - WD3003FZEX
1 x WD WDBSLA0040HNC 4TB 7200 RPM 64MB
1 x WD Se WD2000F9YZ 2TB 7200 RPM 64MB 6.0Gb/s
2 x WD Black 5TB 7200 RPM 6Gb/s 128MB WD5001FZWX
1 x Seagate BarraCuda STBD3000100 3TB 7200 RPM 64MB
1 x Western Digital Red Pro 4TB 7200rpm 64MB
1 x Other drive ( 4 TB ) that I don't have the model number for but can look up later if need be
Current use: iSCSI - Steam Library and data storage (purely Home use). Data is not super important but I do want some redundancy.
*Planning on setting it up in to VOL's one to a R640 I have at home to host a bunch of VM's but can't seem to get the 10GB NIC inside of it to work.*
Current Config:
RAIDZ1 - 6 x 2TB Drives
RAIDZ1 - 3 x 4TB Drives
RAIDZ1 - 3 x 5TB Drives
[Volume Stats]
[Storage Tab]
[iSCSI Setup]
What I wanted to do:
- Have my Steam Library, Movie, Game, TV, Anime, Music storage remote. (aka I build a PC that has no 3.5" HDD mounts and I am stuck with M.2 and SSD on sticky tape)
- Have Semi-redundant storage, nothing crazy but just something to give me peace of mind.
- Have high speed storage
- Work with 10GB networking
What is currently happening:
- Speeds are ok
- iSCSI drops from time to time and I can not reconnect to it for a while and when I finally do, I can not move any data to it without the connection dropping again. Only way to fix this is a hard reboot of the NAS.
From what I have researched, It seems to be because I throw too many write requests at the NAS at one time and iSCSI doesn't like that. That and RAIDZ doesn't pair well with iSCSI? Looking for some advice on the current setup, current config, and things I might have to change to get everything working that way that I want to.
I am sure I forgot some info here so let me know if I need to add anything else.
[Pictures of the current setup](https://imgur.com/a/0iya4)
Current Setup:
MoBo: ASUS Z97-A
Totals:
6 x 2TB
3 x 3TB
3 x 4TB
3 x 5TB
Current Config:
[Volume Stats]
[Storage Tab]
[iSCSI Setup]
- Speeds are ok
