Hi Community!
I'm a happy owner of a ridiculous Freenas installation running on 6-year-old Lenovo laptop through USB network adapter and with new drives that are connected through SATA II & SATA III . Yeah, way to go, I know :D Works good enough anyway.
For some time I had issues with my router (until provider replaced it), in particular, it was rebooting from time to time. On Freenas side this resulted in total net loss. So I had to kneel down by the wall, open the old pal praying 6-year old Lenovo plastic doesn't fall apart into atoms in my hands, and either manually reboot or to try fix the net.
It was troublesome enough so I wrote a couple of scripts that are intended to be used in this situation. I would like your "code review" on them from the FreeNas specifics standpoint. For instance, I spent days torturing
Script #1 - this one is called every 5 minutes by Cron:
Script #2 - this is the "fixnet.sh". I made it a separate script to be able to call it manually when/if needed. "ue0" is the USB Ethernet.
Ping google is added so that when executing manually, I can see the proof with my own eyes.
Now this box successfully survives temporary power loss, router reboots and updates etc.
What do you think of the scripts above?
jail command until I read your puthon scripts and understood I needto actually call iocage :)Script #1 - this one is called every 5 minutes by Cron:
ping -c 1 google.ie
if [ $? != 0 ]
then
./fixnet.sh
else
if [ "$1" = "-v" ]
then
echo "Test successful."
fi
fiScript #2 - this is the "fixnet.sh". I made it a separate script to be able to call it manually when/if needed. "ue0" is the USB Ethernet.
service netif onerestart
ifconfig ue0 up
service routing restart
service dhclient forcerestart ue0
service smbd restart
service nmbd restart
ping -c 1 google.com
jls | grep -v JID | awk '{system("iocage restart " $2)}'
