I can't copy anything out from the server, but I managed to copy this from the footer. The final line appears when I try to boot the plugin.
Apr 17 15:27:29 freenas syslog-ng[1250]: syslog-ng starting up; version='3.6.4'
Apr 17 15:27:29 freenas 90 second watchdog timeout expired. Shutdown terminated.
Apr 17 15:27:29 freenas wbwd0: Failed to disable watchdog: 0x86.
Apr 17 15:27:29 freenas Waiting (max 60 seconds) for system process `vnlru' to stop...done
Apr 17 15:27:29 freenas Waiting (max 60 seconds) for system process `bufdaemon' to stop...done
Apr 17 15:27:29 freenas Waiting (max 60 seconds) for system process `syncer' to stop...
Apr 17 15:27:29 freenas Syncing disks, vnodes remaining...0 0 0 0 0 done
Apr 17 15:27:29 freenas All buffers synced.
Apr 17 15:27:29 freenas Copyright (c) 1992-2016 The FreeBSD Project.
Apr 17 15:27:29 freenas Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Apr 17 15:27:29 freenas The Regents of the University of California. All rights reserved.
Apr 17 15:27:29 freenas FreeBSD is a registered trademark of The FreeBSD Foundation.
Apr 17 15:27:29 freenas FreeBSD 10.3-RELEASE #0 1b72f49(HEAD): Wed Apr 13 23:35:10 PDT 2016
Apr 17 15:27:29 freenas root@build.ixsystems.com:/tank/home/nightlies/CVE910/_BE/objs/tank/home/nightlies/CVE910/_BE/trueos/sys/FreeNAS.amd64 amd64
Apr 17 15:27:29 freenas FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512
Apr 17 15:27:29 freenas CPU: Intel(R) Pentium(R) CPU G840 @ 2.80GHz (2793.72-MHz K8-class CPU)
Apr 17 15:27:29 freenas Origin="GenuineIntel" Id=0x206a7 Family=0x6 Model=0x2a Stepping=7
Apr 17 15:27:29 freenas Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Apr 17 15:27:29 freenas Features2=0xd9ae3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,POPCNT,TSCDLT,XSAVE,OSXSAVE>
Apr 17 15:27:29 freenas AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
Apr 17 15:27:29 freenas AMD Features2=0x1<LAHF>
Apr 17 15:27:29 freenas XSAVE Features=0x1<XSAVEOPT>
Apr 17 15:27:29 freenas VT-x: (disabled in BIOS) PAT,HLT,MTF,PAUSE,EPT,UG,VPID
Apr 17 15:27:29 freenas TSC: P-state invariant, performance statistics
Apr 17 15:27:29 freenas real memory = 7514095616 (7166 MB)
Apr 17 15:27:29 freenas avail memory = 5887799296 (5615 MB)
Apr 17 15:27:29 freenas Event timer "LAPIC" quality 600
Apr 17 15:27:29 freenas ACPI APIC Table: <ALASKA A M I>
Apr 17 15:27:29 freenas FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
Apr 17 15:27:29 freenas FreeBSD/SMP: 1 package(s) x 2 core(s)
Apr 17 15:27:29 freenas cpu0 (BSP): APIC ID: 0
Apr 17 15:27:29 freenas cpu1 (AP): APIC ID: 2
Apr 17 15:27:29 freenas random: <Software, Yarrow> initialized
Apr 17 15:27:29 freenas WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
Apr 17 15:27:29 freenas ioapic0 <Version 2.0> irqs 0-23 on motherboard
Apr 17 15:27:29 freenas kbd1 at kbdmux0
Apr 17 15:27:29 freenas cryptosoft0: <software crypto> on motherboard
Apr 17 15:27:29 freenas aesni0: No AESNI support.
Apr 17 15:27:29 freenas padlock0: No ACE support.
Apr 17 15:27:29 freenas acpi0: <ALASKA A M I> on motherboard
Apr 17 15:27:29 freenas acpi0: Power Button (fixed)
Apr 17 15:27:29 freenas cpu0: <ACPI CPU> on acpi0
Apr 17 15:27:29 freenas cpu1: <ACPI CPU> on acpi0
Apr 17 15:27:29 freenas attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Apr 17 15:27:29 freenas Timecounter "i8254" frequency 1193182 Hz quality 0
Apr 17 15:27:29 freenas Event timer "i8254" frequency 1193182 Hz quality 100
Apr 17 15:27:29 freenas atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Apr 17 15:27:29 freenas Event timer "RTC" frequency 32768 Hz quality 0
Apr 17 15:27:29 freenas hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Apr 17 15:27:29 freenas Timecounter "HPET" frequency 14318180 Hz quality 950
Apr 17 15:27:29 freenas Event timer "HPET" frequency 14318180 Hz quality 550
Apr 17 15:27:29 freenas Event timer "HPET1" frequency 14318180 Hz quality 440
Apr 17 15:27:29 freenas Event timer "HPET2" frequency 14318180 Hz quality 440
Apr 17 15:27:29 freenas Event timer "HPET3" frequency 14318180 Hz quality 440
Apr 17 15:27:29 freenas Event timer "HPET4" frequency 14318180 Hz quality 440
Apr 17 15:27:29 freenas Event timer "HPET5" frequency 14318180 Hz quality 440
Apr 17 15:27:29 freenas Event timer "HPET6" frequency 14318180 Hz quality 440
Apr 17 15:27:29 freenas Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
Apr 17 15:27:29 freenas acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
Apr 17 15:27:29 freenas pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Apr 17 15:27:29 freenas pci0: <ACPI PCI bus> on pcib0
Apr 17 15:27:29 freenas pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
Apr 17 15:27:29 freenas pci1: <ACPI PCI bus> on pcib1
Apr 17 15:27:29 freenas vgapci0: <VGA-compatible display> port 0xf000-0xf03f mem 0xfe000000-0xfe3fffff,0xc0000000-0xcfffffff irq 16 at device 2.0 on pci0
Apr 17 15:27:29 freenas agp0: <SandyBridge desktop GT1 IG> on vgapci0
Apr 17 15:27:29 freenas agp0: aperture size is 256M, detected 262140k stolen memory
Apr 17 15:27:29 freenas vgapci0: Boot video device
Apr 17 15:27:29 freenas pci0: <simple comms> at device 22.0 (no driver attached)
Apr 17 15:27:29 freenas ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfe406000-0xfe4063ff irq 23 at device 26.0 on pci0
Apr 17 15:27:29 freenas usbus0: EHCI version 1.0
Apr 17 15:27:29 freenas usbus0 on ehci0
Apr 17 15:27:29 freenas pci0: <multimedia, HDA> at device 27.0 (no driver attached)
Apr 17 15:27:29 freenas pcib2: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0
Apr 17 15:27:29 freenas pci2: <ACPI PCI bus> on pcib2
Apr 17 15:27:29 freenas pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.1 on pci0
Apr 17 15:27:29 freenas pci3: <ACPI PCI bus> on pcib3
Apr 17 15:27:29 freenas pcib4: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
Apr 17 15:27:29 freenas pci4: <ACPI PCI bus> on pcib4
Apr 17 15:27:29 freenas pcib5: <ACPI PCI-PCI bridge> irq 18 at device 0.0 on pci4
Apr 17 15:27:29 freenas pci5: <ACPI PCI bus> on pcib5
Apr 17 15:27:29 freenas pcib6: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
Apr 17 15:27:29 freenas pci6: <ACPI PCI bus> on pcib6
Apr 17 15:27:29 freenas re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xe000-0xe0ff mem 0xd0004000-0xd0004fff,0xd0000000-0xd0003fff irq 19 at device 0.0 on pci6
Apr 17 15:27:29 freenas re0: Using 1 MSI-X message
Apr 17 15:27:29 freenas re0: Chip rev. 0x2c000000
Apr 17 15:27:29 freenas re0: MAC rev. 0x00200000
Apr 17 15:27:29 freenas miibus0: <MII bus> on re0
Apr 17 15:27:29 freenas rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0
Apr 17 15:27:29 freenas rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
Apr 17 15:27:29 freenas re0: Using defaults for TSO: 65518/35/2048
Apr 17 15:27:29 freenas re0: Ethernet address: c8:60:00:85:44:80
Apr 17 15:27:29 freenas pcib7: <ACPI PCI-PCI bridge> irq 17 at device 28.4 on pci0
Apr 17 15:27:29 freenas pci7: <ACPI PCI bus> on pcib7
Apr 17 15:27:29 freenas pcib8: <ACPI PCI-PCI bridge> irq 16 at device 28.5 on pci0
Apr 17 15:27:29 freenas pci8: <ACPI PCI bus> on pcib8
Apr 17 15:27:29 freenas ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfe405000-0xfe4053ff irq 23 at device 29.0 on pci0
Apr 17 15:27:29 freenas usbus1: EHCI version 1.0
Apr 17 15:27:29 freenas usbus1 on ehci1
Apr 17 15:27:29 freenas isab0: <PCI-ISA bridge> at device 31.0 on pci0
Apr 17 15:27:29 freenas isa0: <ISA bus> on isab0
Apr 17 15:27:29 freenas atapci0: <Intel Cougar Point SATA600 controller> port 0xf110-0xf117,0xf100-0xf103,0xf0f0-0xf0f7,0xf0e0-0xf0e3,0xf0d0-0xf0df,0xf0c0-0xf0cf irq 20 at device 31.2 on pci0
Apr 17 15:27:29 freenas ata2: <ATA channel> at channel 0 on atapci0
Apr 17 15:27:29 freenas ata3: <ATA channel> at channel 1 on atapci0
Apr 17 15:27:29 freenas atapci1: <Intel Cougar Point SATA300 controller> port 0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf090-0xf097,0xf080-0xf083,0xf070-0xf07f,0xf060-0xf06f irq 20 at device 31.5 on pci0
Apr 17 15:27:29 freenas ata4: <ATA channel> at channel 0 on atapci1
Apr 17 15:27:29 freenas ata5: <ATA channel> at channel 1 on atapci1
Apr 17 15:27:29 freenas acpi_button0: <Power Button> on acpi0
Apr 17 15:27:29 freenas uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
Apr 17 15:27:29 freenas ichwd0: <Intel Cougar Point watchdog timer> on isa0
Apr 17 15:27:29 freenas wbwd0: <Nuvoton NCT6776 (0xc3/0x33) Watchdog Timer> at port 0x2e-0x2f on isa0
Apr 17 15:27:29 freenas sc0: <System console> at flags 0x100 on isa0
Apr 17 15:27:29 freenas sc0: VGA <16 virtual consoles, flags=0x300>
Apr 17 15:27:29 freenas vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Apr 17 15:27:29 freenas atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
Apr 17 15:27:29 freenas atkbd0: <AT Keyboard> irq 1 on atkbdc0
Apr 17 15:27:29 freenas kbd0 at atkbd0
Apr 17 15:27:29 freenas atkbd0: [GIANT-LOCKED]
Apr 17 15:27:29 freenas coretemp0: <CPU On-Die Thermal Sensors> on cpu0
Apr 17 15:27:29 freenas est0: <Enhanced SpeedStep Frequency Control> on cpu0
Apr 17 15:27:29 freenas coretemp1: <CPU On-Die Thermal Sensors> on cpu1
Apr 17 15:27:29 freenas est1: <Enhanced SpeedStep Frequency Control> on cpu1
Apr 17 15:27:29 freenas ZFS filesystem version: 5
Apr 17 15:27:29 freenas ZFS storage pool version: features support (5000)
Apr 17 15:27:29 freenas Timecounters tick every 1.000 msec
Apr 17 15:27:29 freenas ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
Apr 17 15:27:29 freenas random: unblocking device.
Apr 17 15:27:29 freenas usbus0: 480Mbps High Speed USB v2.0
Apr 17 15:27:29 freenas usbus1: 480Mbps High Speed USB v2.0
Apr 17 15:27:29 freenas ugen1.1: <Intel> at usbus1
Apr 17 15:27:29 freenas uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
Apr 17 15:27:29 freenas ugen0.1: <Intel> at usbus0
Apr 17 15:27:29 freenas uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
Apr 17 15:27:29 freenas uhub0: 2 ports with 2 removable, self powered
Apr 17 15:27:29 freenas uhub1: 2 ports with 2 removable, self powered
Apr 17 15:27:29 freenas ugen0.2: <vendor 0x8087> at usbus0
Apr 17 15:27:29 freenas uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
Apr 17 15:27:29 freenas ugen1.2: <vendor 0x8087> at usbus1
Apr 17 15:27:29 freenas uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1
Apr 17 15:27:29 freenas uhub2: 4 ports with 4 removable, self powered
Apr 17 15:27:29 freenas uhub3: 6 ports with 6 removable, self powered
Apr 17 15:27:29 freenas ugen1.3: <Kingston> at usbus1
Apr 17 15:27:29 freenas umass0: <Kingston DataTraveler 2.0, class 0/0, rev 2.00/2.00, addr 3> on usbus1
Apr 17 15:27:29 freenas umass0: SCSI over Bulk-Only; quirks = 0xc100
Apr 17 15:27:29 freenas umass0:5:0:-1: Attached to scbus5
Apr 17 15:27:29 freenas ugen1.4: <Logitech> at usbus1
Apr 17 15:27:29 freenas ada0 at ata2 bus 0 scbus0 target 0 lun 0
Apr 17 15:27:29 freenas ada0: <WDC WD5000AZRX-00A8LB0 01.01A01> ATA8-ACS SATA 3.x device
Apr 17 15:27:29 freenas ada0: Serial Number WD-WMC1U2915097
Apr 17 15:27:29 freenas cd0 at ata5 bus 0 scbus3 target 0 lun 0
Apr 17 15:27:29 freenas cd0: <Optiarc DVD RW AD-7261S 1.01> Removable CD-ROM SCSI device
Apr 17 15:27:29 freenas cd0: 150.000MB/s transfers (SATA 1.x, UDMA5, ATAPI 12bytes, PIO 8192bytes)
Apr 17 15:27:29 freenas cd0: Attempt to query device size failed: NOT READY, Medium not present - tray closed
Apr 17 15:27:29 freenas ada0: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
Apr 17 15:27:29 freenas ada0: 476940MB (976773168 512 byte sectors)
Apr 17 15:27:29 freenas ada0: quirks=0x1<4K>
Apr 17 15:27:29 freenas ada0: Previously was known as ad4
Apr 17 15:27:29 freenas ada1 at ata3 bus 0 scbus1 target 0 lun 0
Apr 17 15:27:29 freenas ada1: <ST500DM002-1BD142 KC44> ATA8-ACS SATA 3.x device
Apr 17 15:27:29 freenas ada1: Serial Number Z2ACRBJZ
Apr 17 15:27:29 freenas ada1: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
Apr 17 15:27:29 freenas ada1: 476940MB (976773168 512 byte sectors)
Apr 17 15:27:29 freenas ada1: quirks=0x1<4K>
Apr 17 15:27:29 freenas ada1: Previously was known as ad6
Apr 17 15:27:29 freenas ada2 at ata4 bus 0 scbus2 target 0 lun 0
Apr 17 15:27:29 freenas ada2: <ST500LT012-1DG142 0001SDM1> ATA8-ACS SATA 3.x device
Apr 17 15:27:29 freenas ada2: Serial Number S3P74ML5
Apr 17 15:27:29 freenas ada2: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
Apr 17 15:27:29 freenas ada2: 476940MB (976773168 512 byte sectors)
Apr 17 15:27:29 freenas ada2: quirks=0x1<4K>
Apr 17 15:27:29 freenas ada2: Previously was known as ad8
Apr 17 15:27:29 freenas da0 at umass-sim0 bus 0 scbus5 target 0 lun 0
Apr 17 15:27:29 freenas da0: <Kingston DataTraveler 2.0 1.00> Removable Direct Access SCSI-2 device
Apr 17 15:27:29 freenas da0: Serial Number 0019E06B07A9A8A1FFFF0091
Apr 17 15:27:29 freenas da0: 40.000MB/s transfers
Apr 17 15:27:29 freenas da0: 7692MB (15753216 512 byte sectors)
Apr 17 15:27:29 freenas da0: quirks=0x3<NO_SYNC_CACHE,NO_6_BYTE>
Apr 17 15:27:29 freenas SMP: AP CPU #1 Launched!
Apr 17 15:27:29 freenas Timecounter "TSC-low" frequency 1396858588 Hz quality 1000
Apr 17 15:27:29 freenas Trying to mount root from zfs:freenas-boot/ROOT/9.10-STABLE-201604140622 []...
Apr 17 15:27:29 freenas GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
Apr 17 15:27:29 freenas kernel: re0: link state changed to UP
Apr 17 15:27:29 freenas hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/8/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI> UCP/8/48/0x3f8<EDG,THR,REA,WRI,INV,QUA,PRC> UCF/1/48/0x60<REA,WRI>
Apr 17 15:27:29 freenas kernel: re0: link state changed to DOWN
Apr 17 15:27:29 freenas ums0: <Logitech Optical USB Mouse, class 0/0, rev 2.00/3.40, addr 4> on usbus1
Apr 17 15:27:29 freenas ums0: 3 buttons and [XYZ] coordinates ID=0
Apr 17 15:27:29 freenas vboxdrv: fAsync=0 offMin=0x2e4 offMax=0xaa4
Apr 17 15:27:30 freenas ntpd[1534]: ntpd 4.2.8p6-a (1): Starting
Apr 17 15:27:33 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /sbin/sysctl -n 'kern.maxfilesperproc'
Apr 17 15:27:33 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /usr/local/bin/net -d 0 getlocalsid
Apr 17 15:27:33 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /usr/local/bin/net -d 0 setlocalsid S-1-5-21-2935517764-1545820137-1794740574
Apr 17 15:27:33 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /usr/local/bin/pdbedit -d 0 -i smbpasswd:/tmp/tmpB2xNYV -s /usr/local/etc/smb4.conf -e tdbsam:/var/db/samba4/private/passdb.tdb
Apr 17 15:27:33 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /usr/local/bin/pdbedit -d 0 -L
Apr 17 15:27:34 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Apr 17 15:27:38 freenas smartd[1972]: Device: /dev/ada2, FAILED SMART self-check. BACK UP DATA NOW!
Apr 17 15:27:38 freenas smartd[1972]: Device: /dev/ada2, Failed SMART usage Attribute: 5 Reallocated_Sector_Ct.
Apr 17 15:27:40 freenas mDNSResponder: mDNSResponder (Engineering Build) (Apr 14 2016 06:45:32) starting
Apr 17 15:27:40 freenas mDNSResponder: 8: Listening for incoming Unix Domain Socket client requests
Apr 17 15:27:40 freenas mDNSResponder: mDNS_AddDNSServer: Lock not held! mDNS_busy (0) mDNS_reentrancy (0)
Apr 17 15:27:40 freenas mDNSResponder: CheckNATMappings: Failed to allocate port 5350 UDP multicast socket for PCP & NAT-PMP announcements
Apr 17 15:27:44 freenas mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000801406D60 freenas.local. (Addr) that's already in the list
Apr 17 15:27:44 freenas mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000801407180 25.0.0.10.in-addr.arpa. (PTR) that's already in the list
Apr 17 15:28:40 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /sbin/sysctl -n 'kern.maxfilesperproc'
Apr 17 15:28:40 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /usr/local/bin/net -d 0 getlocalsid
Apr 17 15:28:40 freenas notifier: Performing sanity check on Samba configuration: OK
Apr 17 15:28:41 freenas syslog-ng[3608]: syslog-ng starting up; version='3.6.4'
Apr 17 15:28:41 freenas kernel: pid 1250 (syslog-ng), uid 0: exited on signal 6 (core dumped)
Apr 17 15:28:42 freenas mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000801406D60 freenas.local. (Addr) that's already in the list
Apr 17 15:28:42 freenas mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000801407180 25.0.0.10.in-addr.arpa. (PTR) that's already in the list
Apr 17 15:28:58 freenas notifier: dd: /dev/ada0: Operation not permitted
Apr 17 15:28:58 freenas manage.py: [middleware.exceptions:37] [MiddlewareError: Unable to GPT format the disk "ada0"]
Apr 17 15:29:08 freenas notifier: 32+0 records in
Apr 17 15:29:08 freenas notifier: 32+0 records out
Apr 17 15:29:08 freenas notifier: 33554432 bytes transferred in 0.871653 secs (38495179 bytes/sec)
Apr 17 15:29:08 freenas GEOM: ada0: the primary GPT table is corrupt or invalid.
Apr 17 15:29:08 freenas GEOM: ada0: using the secondary instead -- recovery strongly advised.
Apr 17 15:29:08 freenas notifier: dd: /dev/ada0: short write on character device
Apr 17 15:29:08 freenas notifier: dd: /dev/ada0: end of device
Apr 17 15:29:08 freenas notifier: 33+0 records in
Apr 17 15:29:08 freenas notifier: 32+1 records out
Apr 17 15:29:08 freenas notifier: 33579008 bytes transferred in 0.406139 secs (82678631 bytes/sec)
Apr 17 15:29:09 freenas GEOM: ada1: the primary GPT table is corrupt or invalid.
Apr 17 15:29:09 freenas GEOM: ada1: using the secondary instead -- recovery strongly advised.
Apr 17 15:29:09 freenas notifier: 32+0 records in
Apr 17 15:29:09 freenas notifier: 32+0 records out
Apr 17 15:29:09 freenas notifier: 33554432 bytes transferred in 0.358789 secs (93521360 bytes/sec)
Apr 17 15:29:09 freenas notifier: dd: /dev/ada1: short write on character device
Apr 17 15:29:09 freenas notifier: dd: /dev/ada1: end of device
Apr 17 15:29:09 freenas notifier: 33+0 records in
Apr 17 15:29:09 freenas notifier: 32+1 records out
Apr 17 15:29:09 freenas notifier: 33579008 bytes transferred in 0.455107 secs (73782671 bytes/sec)
Apr 17 15:29:11 freenas notifier: 32+0 records in
Apr 17 15:29:11 freenas notifier: 32+0 records out
Apr 17 15:29:11 freenas notifier: 33554432 bytes transferred in 0.364394 secs (92082846 bytes/sec)
Apr 17 15:29:11 freenas GEOM: ada2: the primary GPT table is corrupt or invalid.
Apr 17 15:29:11 freenas GEOM: ada2: using the secondary instead -- recovery strongly advised.
Apr 17 15:29:14 freenas notifier: dd: /dev/ada2: short write on character device
Apr 17 15:29:14 freenas notifier: dd: /dev/ada2: end of device
Apr 17 15:29:14 freenas notifier: 33+0 records in
Apr 17 15:29:14 freenas notifier: 32+1 records out
Apr 17 15:29:14 freenas notifier: 33579008 bytes transferred in 3.674970 secs (9137220 bytes/sec)
Apr 17 15:29:15 freenas notifier: vfs.zfs.vdev.larger_ashift_minimal: 0 -> 1
Apr 17 22:29:15 freenas devd: Executing 'logger -p kern.notice -t ZFS 'vdev state changed, pool_guid=17302377520989544210 vdev_guid=10232348827713496374''
Apr 17 15:29:15 freenas ZFS: vdev state changed, pool_guid=17302377520989544210 vdev_guid=10232348827713496374
Apr 17 22:29:15 freenas devd: Executing 'logger -p kern.notice -t ZFS 'vdev state changed, pool_guid=17302377520989544210 vdev_guid=292201774566710442''
Apr 17 15:29:15 freenas ZFS: vdev state changed, pool_guid=17302377520989544210 vdev_guid=292201774566710442
Apr 17 22:29:15 freenas devd: Executing 'logger -p kern.notice -t ZFS 'vdev state changed, pool_guid=17302377520989544210 vdev_guid=9344248354140503450''
Apr 17 15:29:15 freenas ZFS: vdev state changed, pool_guid=17302377520989544210 vdev_guid=9344248354140503450
Apr 17 15:29:22 freenas notifier: vfs.zfs.vdev.larger_ashift_minimal: 1 -> 0
Apr 17 15:29:25 freenas GEOM_ELI: Device ada0p1.eli created.
Apr 17 15:29:25 freenas GEOM_ELI: Encryption: AES-XTS 128
Apr 17 15:29:25 freenas GEOM_ELI: Crypto: software
Apr 17 15:29:25 freenas GEOM_ELI: Device ada1p1.eli created.
Apr 17 15:29:25 freenas GEOM_ELI: Device ada2p1.eli created.
Apr 17 15:29:25 freenas notifier: Mounting late file systems:.
Apr 17 15:29:25 freenas notifier: Stopping collectd.
Apr 17 15:29:25 freenas notifier: Waiting for PIDS: 2562.
Apr 17 15:29:26 freenas notifier: Starting collectd.
Apr 17 15:29:30 freenas notifier: Stopping collectd.
Apr 17 15:29:30 freenas notifier: Waiting for PIDS: 4363.
Apr 17 15:29:30 freenas notifier: Starting collectd.
Apr 17 15:29:30 freenas notifier: kern.corefile: %N.core -> /var/db/system/cores/%N.core
Apr 17 15:29:31 freenas syslog-ng[4731]: syslog-ng starting up; version='3.6.4'
Apr 17 15:29:32 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /usr/local/bin/net -d 0 getlocalsid
Apr 17 15:29:32 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /usr/local/bin/net -d 0 setlocalsid S-1-5-21-2935517764-1545820137-1794740574
Apr 17 15:29:32 freenas notifier: Unable to set SID to S-1-5-21-2935517764-1545820137-1794740574
Apr 17 15:29:32 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /sbin/sysctl -n 'kern.maxfilesperproc'
Apr 17 15:29:33 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /usr/local/bin/pdbedit -d 0 -i smbpasswd:/tmp/tmpXCHev2 -s /usr/local/etc/smb4.conf -e tdbsam:/var/db/samba4/private/passdb.tdb
Apr 17 15:29:33 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /usr/local/bin/smbpasswd -e 'root'
Apr 17 15:29:33 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /usr/local/bin/pdbedit -d 0 -L
Apr 17 15:29:33 freenas generate_smb4_conf.py: [common.pipesubr:61] Popen()ing: /usr/local/bin/net -d 0 sam rights grant root SeTakeOwnershipPrivilege SeBackupPrivilege SeRestorePrivilege
Apr 17 15:29:33 freenas notifier: Importing account for root...ok
Apr 17 15:29:33 freenas notifier: Enabled user root.
Apr 17 15:29:33 freenas notifier: Granted SeTakeOwnershipPrivilege to FREENAS\root
Apr 17 15:29:33 freenas notifier: Granted SeBackupPrivilege to FREENAS\root
Apr 17 15:29:33 freenas notifier: Granted SeRestorePrivilege to FREENAS\root
Apr 17 15:29:33 freenas notifier: winbindd not running? (check /var/run/samba/winbindd.pid).
Apr 17 15:29:33 freenas notifier: smbd not running? (check /var/run/samba/smbd.pid).
Apr 17 15:29:33 freenas notifier: nmbd not running? (check /var/run/samba/nmbd.pid).
Apr 17 15:29:34 freenas notifier: Stopping mdnsd.
Apr 17 15:29:34 freenas mDNSResponder: mDNSResponder (Engineering Build) (Apr 14 2016 06:45:32) stopping
Apr 17 15:29:34 freenas mDNSResponder: mDNS_FinalExit failed to send goodbye for: 0000000801483580 01 26 _http._tcp.local. PTR freenas._http._tcp.local.
Apr 17 15:29:34 freenas notifier: Starting mdnsd.
Apr 17 15:29:34 freenas mDNSResponder: mDNSResponder (Engineering Build) (Apr 14 2016 06:45:32) starting
Apr 17 15:29:34 freenas mDNSResponder: 10: Listening for incoming Unix Domain Socket client requests
Apr 17 15:29:34 freenas mDNSResponder: mDNS_AddDNSServer: Lock not held! mDNS_busy (0) mDNS_reentrancy (0)
Apr 17 15:29:34 freenas mDNSResponder: CheckNATMappings: Failed to allocate port 5350 UDP multicast socket for PCP & NAT-PMP announcements
Apr 17 15:29:35 freenas mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000801406D60 freenas.local. (Addr) that's already in the list
Apr 17 15:29:35 freenas mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000801407180 25.0.0.10.in-addr.arpa. (PTR) that's already in the list
Apr 17 15:29:36 freenas notifier: Stopping smartd.
Apr 17 15:29:36 freenas notifier: Waiting for PIDS: 1982.
Apr 17 15:29:37 freenas notifier: smartd not running? (check /var/run/smartd.pid).
Apr 17 15:29:37 freenas notifier: Starting smartd.
Apr 17 15:29:38 freenas smartd[5072]: Device: /dev/ada2, FAILED SMART self-check. BACK UP DATA NOW!
Apr 17 15:29:38 freenas smartd[5072]: Device: /dev/ada2, Failed SMART usage Attribute: 5 Reallocated_Sector_Ct.
Apr 17 15:33:11 freenas warden: Building new Jail... Please wait...
Apr 17 15:33:11 freenas warden: zfs clone main/.warden-template-pluginjail@clean main/transmission_1
Apr 17 15:33:14 freenas warden: Success!
Apr 17 15:33:14 freenas warden: Jail created at /mnt/main/transmission_1
Apr 17 22:33:14 freenas devd: Executing '/etc/pccard_ether bridge0 start'
Apr 17 15:33:15 freenas bridge0: Ethernet address: 02:54:22:9d:8f:00
Apr 17 15:33:15 freenas kernel: bridge0: link state changed to UP
Apr 17 15:33:15 freenas kernel: re0: promiscuous mode enabled
Apr 17 15:33:15 freenas epair0a: Ethernet address: 02:ff:20:00:04:0a
Apr 17 15:33:15 freenas epair0b: Ethernet address: 02:ff:70:00:05:0b
Apr 17 15:33:15 freenas kernel: epair0a: link state changed to UP
Apr 17 15:33:15 freenas kernel: epair0b: link state changed to UP
Apr 17 15:33:15 freenas kernel: re0: link state changed to DOWN
Apr 17 15:33:15 freenas kernel: epair0a: promiscuous mode enabled
Apr 17 22:33:15 freenas devd: Executing '/etc/pccard_ether epair0a start'
Apr 17 22:33:15 freenas devd: Executing '/etc/pccard_ether epair0b start'
Apr 17 22:33:15 freenas devd: Executing '/etc/rc.d/dhclient quietstart epair0a'
Apr 17 15:33:15 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair0b
Apr 17 22:33:19 freenas devd: Executing '/etc/rc.d/dhclient quietstart re0'
Apr 17 15:33:19 freenas kernel: re0: link state changed to UP
Apr 17 15:33:27 freenas dhclient: New IP Address (re0): 10.0.0.25
Apr 17 15:33:27 freenas dhclient: New Subnet Mask (re0): 255.255.255.0
Apr 17 15:33:27 freenas dhclient: New Broadcast Address (re0): 10.0.0.255
Apr 17 15:33:27 freenas dhclient: New Routers (re0): 10.0.0.1
Apr 17 15:33:28 freenas notifier: Performing sanity check on nginx configuration:
Apr 17 15:33:28 freenas notifier: nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
Apr 17 15:33:28 freenas notifier: nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Apr 17 15:33:30 freenas mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 00000008014D2D60 freenas.local. (Addr) that's already in the list
Apr 17 15:33:30 freenas mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 00000008014D3180 25.0.0.10.in-addr.arpa. (PTR) that's already in the list
Apr 17 15:33:32 freenas manage.py: [freeadmin.navtree:629] An error occurred while unserializing from http://10.0.0.25/plugins/transmission/1/_s/treemenu: No JSON object could be decoded
Apr 17 15:34:12 freenas manage.py: [plugins.utils:91] Couldn't retrieve http://10.0.0.25/plugins/transmission/1/_s/status: No JSON object could be decoded
Apr 17 15:34:31 freenas manage.py: [freeadmin.navtree:629] An error occurred while unserializing from http://10.0.0.25/plugins/transmission/1/_s/treemenu: No JSON object could be decoded
Apr 17 15:34:44 freenas manage.py: [freeadmin.navtree:629] An error occurred while unserializing from http://10.0.0.25/plugins/transmission/1/_s/treemenu: No JSON object could be decoded
Stop refresh
