hello all...
I had forgotten about the freenas/UI option (i had just been using the old style) anyway, everytime I open it up, I get a couple of errors (none when using the old interface)
anyting i need to care about or easily correctable?
ALSO (maybe a new topic line needed)
but I'm afraid to update past FreeNAS-11.1-U7
THe reason being, is everytime I reboot the system, it gets stuck in a constant reboot...... I will then push the power button, wait a few, push it again to start up....boots just fine.
Thoughts?
Error 201:[ENOMETHOD] Method "summary" not found in "network.general"
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 906, in _method_lookup
serviceobj = self.get_service(service)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 823, in get_service
return self.__services[name]
KeyError: 'network.general'
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 150, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 915, in call_method
serviceobj, methodobj = self._method_lookup(message['method'])
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 909, in _method_lookup
raise CallError(f'Method "{method_name}" not found in "{service}"', CallError.ENOMETHOD)
middlewared.service_exception.CallError: [ENOMETHOD] Method "summary" not found in "network.general"
Error 22:rrdtool failed: ERROR: opening '/var/db/collectd/rrd/localhost//disk-da60/disk_ops.rrd': No such file or directory
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 921, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 884, in _call
return await methodobj(*args)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 491, in nf
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/stats.py", line 111, in get_data
raise ValueError('rrdtool failed: {}'.format(err.decode()))
ValueError: rrdtool failed: ERROR: opening '/var/db/collectd/rrd/localhost//disk-da60/disk_ops.rrd': No such file or directory
Thoughts?
