Suddenly I can't reach TrueNas web interface but other services seems working well.
File /var/log/nginx/error.log contains a lot of errors; following the last ones:
I restart ngnix it but the problem is yet present.
Ports 80 and 443 seems open:
but when I try to access web interface there is a message that say (transalated from italian):
Best Regards,
Antonio
... Dec 21 18:18:06 freenas-sm nginx: 2020/12/21 18:18:06 [error] 11690#100975: *16 kevent() reported that connect() failed (61: Connection refused) while connecting to upstream, client: 192.168.50.132, server: localhost, request: "GET /websocket HTTP/1.1", upstream: "http://127.0.0.1:6000/websocket", host: "freenas-emx.localdomain:443" Dec 21 18:18:07 freenas-sm nginx: 2020/12/21 18:18:07 [error] 11690#100975: *18 kevent() reported that connect() failed (61: Connection refused) while connecting to upstream, client: 192.168.50.132, server: localhost, request: "GET /websocket HTTP/1.1", upstream: "http://127.0.0.1:6000/websocket", host: "freenas-emx.localdomain:80"
$ nmap freenas-emx -p 80,443 Starting Nmap 7.80 ( https://nmap.org ) at 2020-12-21 18:32 CET Nmap scan report for freenas-emx (192.168.50.3) Host is up (0.00027s latency). rDNS record for 192.168.50.3: freenas-emx.localdomain PORT STATE SERVICE 80/tcp open http 443/tcp open https Nmap done: 1 IP address (1 host up) scanned in 0.10 seconds
Connect to TrueNAS... Are you sure that TrueNAS system is switched on and connected to the network.Best Regards,
Antonio
