Hi, I used the replication function to "copy" 40TB of data to a new pool. I am now planning to repurpose the disks from the original pool so all data will be deleted. TrueNAS shows the replication task as completed and doing a simple folder properties view in Windows shows identical folder/file count and size. However, I am accustomed to using TeraCopy in Windows to verify the checksum of the copied files to ensure the copy process was completed without any file corruption.
Is there a similar function or way to do this in TrueNAS? Or does the nature of ZFS render this an unnecessary step? Thanks for any advice.
