Using FreeNAS shares from OS X
I wasn't really sure where to put this, so I post this here.
Whenever I access my FreeNAS shares from my Hackintosh machine (OS X 10.9.1) the server hangs or spontaneously reboots after a few minutes. This happens even sooner when attempting to write files to the shares. No matter if I use CIFS or AFP shares.
The problem appears since I upgraded the server to FreeNAS 9.x, under 8.x it never happened.
Also, it never happens when accessing from Windows
Maybe not use a Hackintosh? Can anyone be surprised that when you used non-standard software/OSes that things don't work like they do normally? ;)
D
dlavigne
Guest
How much RAM? What driver for the NIC (from ifconfig)? Which version of FreeNAS did you upgrade to?
MoB
Maybe you can provide us with system.log wich is noramlly in /var/log folder to help you ?
