Upgrading from FreeNAS Build 8.0.4-p3x64 to 8.2.0p1-x64
JIsabelle218
Greetings all,
I'm trying to upgrade from 8.0.4-p3x64 to 8.2.0p1-x64 using GUI
I've tried re-D/Ling and I'm using "FreeNAS-8.2.0-RELEASE-p1-x64.GUI_Upgrade.xz" and sha256 checksum of "9d035f2def3d4a196084b49c3049f3ef7ba924da4cc45ea6564b70df421b21b8"
Go through all the standard upgrade steps:
Click update firmware, tell it where to save, etc.
Nothing different than I've done in the past. . .
System unpacks and appears to install, reboots twice as usual.
I log back in and FreeNAS Build is still: FreeNAS-8.0.4-RELEASE-p3-x64 (11703)
I tried to copy and paste the console but I couldn't get it all before the reboot below is what I got. . .is this stored anywhere on the drives, I couldn't find. . .and copying and pasting doesn't seem to be the most efficient.
Thanks
  • FreeNAS-8.2.0-RELEASE-p1-x64.GUI_Upgrade.xz.sha256.txt
sully
I didn't have success doing a GUI upgrade, from 8.0.4 > 8.2 with the .xz, I needed to use the .txz. I believe something was changed, I can't recall the post with the details, but mentioned something about post 8.0.2 (i think) update recommended you use the .txz GUI upgrade file.
ben
FreeNAS GUI Developer
8.0.4 to 8.2.0 should be the XZ. Only 8.2.0 beta 3 and later require TXZ to upgrade.
