Upgrading from 2x1TB mirror to 4x1TB
Magnetz
I have a dell T20 (12GB ram) with 2x1TB drives in a mirror with encryption that I use to store my backups, I don't have AES-NI so CPU is the bottleneck but performance is generally OK.
How should I add my 2 new 1tb drives? Another mirror in the same pool? Another mirror in a different pool, or go raidz2?
I don't want to put much more load on the CPU, so I guess a mirror is my best bet?
BigDave
FreeNAS Enthusiast
Help members help you by posting the hardware specs for your server.
My confusion is...
When looking up your Dell T20, it seems to be listing a Xeon CPU which should
indeed have AES capability?
We have no knowledge of your situation, so without details, recommendations/suggestions
will have no worth. Sorry!
Robert Trevellyan
Pony Wrangler
Magnetz
I have my datasets backed up on a single 1TB external drive so it would be possible for me to rebuild using raidZ2 but it seems another mirror will probably be easier and more manageable.
I have 4x1TB and 1x2TB drives total and my aim is to have redundancy on the NAS and then have enough external storage to take a single copy
Robert Trevellyan
Pony Wrangler
Mirrors give you the greatest flexibility, but RAIDZ2 is more reliable. If you have more than 4 disks, the space overhead of mirrors may be a factor, but not in a 4-disk system.
