Hi, I recently upgraded my FreeNAS (hp microserver N40L, 8GB RAM) from 11.2-U8 to 11.3-U4.
Before this I stored the configuration and migrated the warden jails to iocage jails. Some of the jails like the pluginjail and the dlna_1 jail lost their network ability, but I managed it with the GUI to get them back and up running.
Then I started the Backup in the system>update UI. It stucked at 65% 1/4 and pressing shift+F5 gave me the webinspector in FF, F5 switched me back into the webGUI, and I retried the upgrade.
After some time I pressed F5 again, due to the 65% 1/4 hanging screen, and on a particular Window, that I can't remember, it instructed me to reboot, because the system had been upgraded.
After the reboot the webGUI only worked particulary. Only the sub menue under system worked properly. All other buttons were without function. On the right in the head of the webUI there was a possibility to switch the webUI to the older one(?), but I don't remember exactly. Can I switch back to the other webUI? Do I have the recent webUI running?
That webUI worked and responsed normally.
I then tried to get the iocage jails working, but they didn't.
I noticed bizarre behavior regarding versions, and the oldest warden Jails with 8.3 and 9.1-RELEASE (pluginjail, dlna_1).
Before upgrading, after migrate_warden.py
After
There is also an issue with mysql and php-fpm in the nextcloud iocage, which was 11.2-RELEASE before upgrading.
Undefined symbol "setproctitle_fast@FBSD_1.5"
Pastebin https://pastebin.ubuntu.com/p/WhF36S2r9X/
root@floogy:~ # iocage
| JID | NAME | STATE | RELEASE | IP4 |
| - | FAMP | down | 11.0-RELEASE | - |
| - | dlna_1 | down | 9.1-RELEASE | - |
| - | firefly_1 | down | 11.0-RELEASE | - |
| 10 | nextcloud | up | 11.2-RELEASE | DHCP |
| - | nextcloud_1 | down | 10.3-RELEASE | - |
| - | pluginjail | down | 8.3-RELEASE | 172.16.240.25 |
root@floogy:~ # iocage df
| NAME | CRT | RES | QTA | USE | AVA |
| FAMP | 2.50x | none | none | 3.19G | 3.40T |
| dlna_1 | 2.82x | none | none | 1.13G | 3.40T |
| firefly_1 | 2.59x | none | none | 794M | 3.40T |
| nextcloud | 1.27x | none | none | 16.9G | 3.40T |
| nextcloud_1 | 1.50x | none | none | 4.94G | 3.40T |
| pluginjail | 1.96x | none | none | 3.62G | 3.40T |
root@floogy:~ # bash -c in {dlna_1,firefly_1,nextcloud_1,FAMP} ; do /usr/local/sbin/migrate_warden.py -v -j ${jail} -p datapool ; done '
-- Migrating: dlna_1 --
dlna_1 is running, please stop it first.
-- Migrating: firefly_1 --
firefly_1 is running, please stop it first.
-- Migrating: nextcloud_1 --
nextcloud_1 is running, please stop it first.
-- Migrating: FAMP --
FAMP is running, please stop it first.
root@floogy:~ # warden list
ID AUTOSTART STATUS TYPE
dlna_1 Enabled Running pluginjail
FAMP Enabled Running standard
firefly_1 Enabled Running pluginjail
nextcloud_1 Enabled Running pluginjail
pluginjail Enabled Running standard
root@floogy:~ # iocage list
root@floogy:~ # bash -c 'for jail in {pluginjail,fly_1,nextcloud_1,FAMP} ; do /usr/local/sbin/migrate_warden.py -v -j ${jail} -p datapool ; done'
dne'
-- Migrating: pluginjail --
NAT isn't supported by iocage, not migrating property.
TIME SENT SNAPSHOT
18:36:40 125K datapool/jails/pluginjail@WardenMigration_2020-08-24
18:38:51 5.20G datapool/jails/pluginjail@WardenMigration_2020-08-24
TIME SENT SNAPSHOT
18:39:05 1.26M datapool/jails/dlna_1@WardenMigration_2020-08-24
18:40:17 2.58G datapool/jails/dlna_1@WardenMigration_2020-08-24
TIME SENT SNAPSHOT
18:40:32 9.31M datapool/jails/firefly_1@WardenMigration_2020-08-24
18:41:11 1.63G datapool/jails/firefly_1@WardenMigration_2020-08-24
TIME SENT SNAPSHOT
18:41:25 241K datapool/jails/nextcloud_1@WardenMigration_2020-08-24
18:44:12 6.96G datapool/jails/nextcloud_1@WardenMigration_2020-08-24
TIME SENT SNAPSHOT
18:44:27 171K datapool/jails/FAMP@WardenMigration_2020-08-24
18:46:57 5.48G datapool/jails/FAMP@WardenMigration_2020-08-24
root@floogy:~ #
root@floogy:~ # bash -c 'for i in {dlna_1,firefly_1,nextcloud_1,FAMP,pluginjail} ; do warden auto ${i} ; done'
Disabled autostart for dlna_1
Disabled autostart for firefly_1
Disabled autostart for nextcloud_1
Disabled autostart for FAMP
Disabled autostart for pluginjail
dlna_1 Disabled Stopped pluginjail
FAMP Disabled Stopped standard
firefly_1 Disabled Stopped pluginjail
nextcloud_1 Disabled Stopped pluginjail
pluginjail Disabled Stopped standard
After
root@floogy:~ # iocage upgrade -r 11.3-RELEASE nextcloud
Snapshotting nextcloud...
Snapshot already exists
Updating plugin INDEX...
Running upgrade...
Updating plugin artifact...
Cloning git repository
Branch 11.3-RELEASE does not exist at https://github.com/freenas/iocage-plugin-nextcloud.git!
Using "master" branch for plugin, this may not work with your RELEASE
Removing old pkgs...
Checking integrity... done (0 conflicting)
Deinstallation has been requested for the following 69 packages (of 0 packages in the universe):
Installed packages to be REMOVED:
ca_root_nss-3.55
curl-7.72.0
php74-zlib-7.4.9
pkg-1.14.7
png-1.6.37
protobuf-3.12.4,1
tiff-4.1.0
webp-1.1.0
Number of packages to be removed: 69
The operation will free 712 MiB.
[nextcloud] [1/69] Deinstalling nextcloud-php74-19.0.1...
You may need to manually remove /usr/local/www/nextcloud/config/config.php if it is no longer needed.
[nextcloud] [1/69] Deleting files for nextcloud-php74-19.0.1: .......... done
[nextcloud] [2/69] Deinstalling php74-xsl-7.4.9...
[nextcloud] [68/69] Deinstalling png-1.6.37...
[nextcloud] [68/69] Deleting files for png-1.6.37: .......... done
[nextcloud] [69/69] Deinstalling protobuf-3.12.4,1...
[nextcloud] [69/69] Deleting files for protobuf-3.12.4,1: .......... done
Installing new pkgs...
Repo: iocage-plugins already exists, skipping!
Testing Host DNS response to pkg.FreeBSD.org
Testing nextcloud's SRV response to pkg.FreeBSD.org
Testing nextcloud's DNSSEC response to pkg.FreeBSD.org
Installing plugin packages:
- nextcloud-php74...
- nginx...
- mysql57-server...
nextcloud successfully upgraded!
root@floogy:~ # iocage exec nextcloud freebsd-version
11.2-RELEASE-p15
11.2-RELEASE-p15
freebsd-version could not be found at /mnt/datapool/iocage/jails/dlna_1/root/bin/freebsd-version
freebsd-version could not be found at /mnt/datapool/iocage/jails/pluginjail/root/bin/freebsd-version
| 2 | FAMP | up | 11.0-RELEASE | DHCP |
| - | dlna_1 | CORRUPT | N/A | N/A |
| - | firefly_1 | down | 11.0-RELEASE | 172.16.240.23 |
| 8 | nextcloud | up | 11.3-RELEASE | DHCP |
| - | nextcloud_1 | down | 10.3-RELEASE | 172.16.240.16 |
| - | pluginjail | CORRUPT | N/A | N/A |
11.2-RELEASE-p15
root@floogy:~ # iocage upgrade -r 11.3-RELEASE FAMP
src component not installed, skipped
Looking up update.FreeBSD.org mirrors... 3 mirrors found.
Fetching public key from update2.freebsd.org... done.
Fetching metadata signature for 11.0-RELEASE from update2.freebsd.org... done.
Fetching metadata index... done.
Fetching 2 metadata files... done.
Inspecting system... done.
The following components of FreeBSD seem to be installed:
world/base world/doc world/lib32
The following components of FreeBSD do not seem to be installed:
world/base-dbg world/lib32-dbg
Does this look reasonable (y/n)? ^C
Aborted!
root@floogy:~ # iocage upgrade -r 11.0-RELEASE pluginjail
root@floogy:~ # iocage exec FAMP freebsd-version
11.0-RELEASE-p1
root@floogy:~ # iocage console nextcloud Last login: Tue Aug 25 00:02:31 on pts/5 FreeBSD 11.3-RELEASE-p11 (FreeNAS.amd64) #0 r325575+fb17f3e15b8(HEAD): Tue Jul 28 11:09:10 EDT 2020 Welcome to FreeBSD! [...] root@nextcloud:~ # freebsd-version ; uname -a 11.2-RELEASE-p15 FreeBSD nextcloud 11.3-RELEASE-p11 FreeBSD 11.3-RELEASE-p11 #0 r325575+fb17f3e15b8(HEAD): Tue Jul 28 11:09:10 EDT 2020 root@tnbuilds05.tn.ixsystems.net:/freenas-releng/freenas/_BE/objs/freenas-releng/freenas/_BE/os/sys/FreeNAS.amd64 amd64 root@nextcloud:~ # ps axu | egrep 'ngin|mysql|fpm' root 61898 0.0 0.1 11672 7384 - IsJ 00:10 0:00.00 nginx: master process /usr/local/sbin/nginx www 61899 0.0 0.1 11672 7848 - IJ 00:10 0:00.00 nginx: worker process (nginx) www 61900 0.0 0.1 11672 7844 - IJ 00:10 0:00.00 nginx: worker process (nginx) root 86949 0.0 0.0 6740 2584 4 R+J 10:23 0:00.00 egrep ngin|mysql|fpm root@nextcloud:/usr/local/www/nextcloud # /usr/local/etc/rc.d/mysql-server status mysql is not running. root@nextcloud:/usr/local/www/nextcloud # /usr/local/etc/rc.d/mysql-server start Starting mysql. /root/.acme.sh/acme.sh.csh: Permission denied. root@nextcloud:/usr/local/www/nextcloud # /usr/local/etc/rc.d/mysql-server status mysql is not running. root@nextcloud:/usr/local/www/nextcloud # root@nextcloud:/usr/local/www/nextcloud # ls -l .acme.sh/acme.sh.csh -rwxr-xr-x 1 root wheel 78 Apr 4 2019 /root/.acme.sh/acme.sh.csh root@nextcloud:/usr/local/www/nextcloud # head /root/.acme.sh/acme.sh.csh setenv LE_WORKING_DIR "/root/.acme.sh" alias acme.sh "/root/.acme.sh/acme.sh" root@nextcloud:/usr/local/www/nextcloud # tail /.acme.sh/acme.sh.csh setenv LE_WORKING_DIR "/root/.acme.sh" alias acme.sh "/root/.acme.sh/acme.sh" root@nextcloud:/usr/local/www/nextcloud # head /root/.acme.sh/acme.sh. #!/usr/local/bin/bash VER=2.8.7 PROJECT_NAME="acme.sh" PROJECT_ENTRY="acme.sh" PROJECT="https://github.com/acmesh-official/$PROJECT_NAME" root@nextcloud:~ # /usr/local/etc/rc.d/php-fpm restart Performing sanity check on php-fpm configuration: [25-Aug-2020 12:16:15] NOTICE: configuration file /usr/local/etc/php-fpm.conf test is successful php_fpm not running? (check /var/run/php-fpm.pid). Performing sanity check on php-fpm configuration: [25-Aug-2020 12:16:15] NOTICE: configuration file /usr/local/etc/php-fpm.conf test is successful Starting php_fpm. /usr/local/sbin/php-fpm: Undefined symbol "setproctitle_fast@FBSD_1.5" [25-Aug-2020 12:16:16] ERROR: no data have been read from pipe /usr/local/etc/rc.d/php-fpm: WARNING: failed to start php_fpm
