Just today I finished my transition from 6x4TB raidz2 to 6x14TB raidz2 expecting a massive jump in capacity. To my shock I have exactly half the storage available according to TrueNAS. It says 42.77TiB which translates to 47TB while I should have 56TB according to the ZFS calculator (https://raidcalculators.com/zfs-raidz-capacity.php). So I'm missing a good 10TB basically.
Can someone please explain what's going wrong? I would greatly appreciate it. Thanks in advance.
Last login: Wed Nov 24 14:51:46 on pts/7
FreeBSD 12.2-RELEASE-p10 b26f74b5984(HEAD) TRUENAS
TrueNAS (c) 2009-2021, iXsystems, Inc.
All rights reserved.
TrueNAS code is released under the modified BSD license with some
files copyrighted by (c) iXsystems, Inc.
For more information, documentation, help or support, go here:
http://truenas.com
Welcome to FreeNAS
Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
root@freenas[~]# zpool status
pool: STORAGE
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
scan: resilvered 3.18T in 04:52:46 with 0 errors on Wed Nov 24 15:33:16 2021
NAME STATE READ WRITE CKSUM
STORAGE ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/77e04f79-4c13-11ec-9276-7085c262d57f.eli ONLINE 0 0 0
gptid/8a6947a7-4c9e-11ec-9276-7085c262d57f.eli ONLINE 0 0 0
gptid/ce8cb512-4d55-11ec-a11c-7085c262d57f.eli ONLINE 0 0 1
gptid/dfb07a15-4d55-11ec-a11c-7085c262d57f.eli ONLINE 0 0 0
gptid/0b17bf60-4c7a-11ec-9276-7085c262d57f.eli ONLINE 0 0 0
gptid/41bdfbb1-4c7a-11ec-9276-7085c262d57f.eli ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
still be used, but some features are unavailable.
the features. See zpool-features(5) for details.
scan: scrub repaired 0B in 00:00:27 with 0 errors on Thu Nov 18 03:45:27 2021
NAME
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
