Upgrade from 11.2 to 11.3 - Transmission and Syncthing OK?
urza
I am preparing to upgrade from 11.2 U8 to 11.3 and just wanted to ask if anyone upgraded this way with Transmission and Syncthing plugins (plugin v2, iocage) and they continue working? I would like to avoid debugging them if they should stop working.
It was already quite a lot of work to get them working the first time :)
I will be glad if you can confirm successful upgrade with any of these plugins without any problem.
Thank you
Samuel Tai
11.2 uses Warden for jails/plugins. 11.3 switches to iocage, as warden is abandoned upstream. You'll need to recreate your plugins, or run the migration script /usr/local/sbin/migrate_warden.py after the upgrade.
Thousandbuckle
Hi Samuel, can you explain in a bit more detail what the steps are? Do I first migrate to 11.3 then run a migration script? Do I have to run the script separately for each jail to upgrade or does it upgrade all of the old Warden jails to IoCage?
