I am new to upgrading FreeNAS firmware. Have been using FreeNAS for about 6 months now.
I have read and searched quite a bit, but found conflicting answers, so here I am writing this post.
I currently have Supermicro x8dth-6f-o motherboard.
I am getting the following warning: WARNING: Firmware version 11 does not match driver version 21 for /dev/mps0. Please flash controller to P21 IT firmware.
I am currently on FreeNAS-9.10.2-U3 (e1497f269)
I tried searching for stepwise guide, but couldn't find one for IR to IT more firmware update. (this is a production system, so can't conduct much experiments.)
Please help...! Thank you.
Some more info: I have LSI SAS 2008 (B2) in IR mode, and needs to be flashed to P20 IT
Output of
Looks like that is the only onboard controller.
Output of
Output of
sas2flash -listCode:
LSI Corporation SAS2 Flash Utility Version 16.00.00.00 (2013.03.01) Copyright (c) 2008-2013 LSI Corporation. All rights reserved Adapter Selected is a LSI SAS: SAS2008(B2) Controller Number : 0 Controller : SAS2008(B2) PCI Address : 00:05:00:00 SAS Address : 5xxxxx8-0-0xx1-0xx0 NVDATA Version (Default) : 0a.03.00.04 NVDATA Version (Persistent) : 0a.03.00.04 Firmware Product ID : 0x2713 (IR) Firmware Version : 11.00.00.00 NVDATA Vendor : LSI NVDATA Product ID : SAS2008-IR BIOS Version : 07.21.00.00 UEFI BSD Version : N/A FCODE Version : N/A Board Name : SMC2008-IR Board Assembly : N/A Board Tracer Number : N/A Finished Processing Commands Successfully. Exiting SAS2Flash.
Output of
sas2ircu listCode:
LSI Corporation SAS2 IR Configuration Utility. Version 20.00.00.00 (2014.09.18) Copyright (c) 2008-2014 LSI Corporation. All rights reserved. Adapter Vendor Device SubSys SubSys Index Type ID ID Pci Address Ven ID Dev ID ----- ------------ ------ ------ ----------------- ------ ------ 0 SAS2008 1000h 72h 00h:05h:00h:00h 15d9h 0400h SAS2IRCU: Utility Completed Successfully.
lspci | grep LSICode:
05:00.0 Serial Attached SCSI controller: LSI Logic / Symbios Logic SAS2008 PCI-Express Fusion-MPT SAS-2 [Falcon] (rev 03)
