Updated SMB/CIF auditing instructions for v11
JohnL7
I found the following threads here on the forum but they are all stale and for older versions of FreeNAS:
https://forums.freenas.org/index.php?threads/freenas-samba-full_audit-log-user-activity.10007/
https://forums.freenas.org/index.ph...on-samba-shares-full_audit-freenas-9-3.13840/
https://forums.freenas.org/index.ph...rs-activity-with-full_audit-vfs-object.10076/
I was looking at getting updated instructions that work with version 11.1 so I can get this setup. Does anyone have updated instructions as when I tried to get this working nothing appears to be logging the way the sample outputs are shown in the thread.
Thanks in advance!
I add this to my Auxiliary Parameters field in Services, SMB:
full_audit:prefix = %u|%I|%m|%S
full_audit:priority = notice
full_audit:failure = connect
full_audit:success = open mkdir unlink rmdir rename
and then on the Share itself add the VFS Object full_audit
JohnL7
Did you need to restart any services? Reboot the entire box? I also wanted to confirm that this just modifies the entries being sent to the messages log and not anywhere else correct?
frouty
@Johnny Fartpants I made what you write :
- auxiliary parameters for service samba,
- full_audit in a share dataset
- restart the SMB service.
And from an other linux machine client did a : smbclient //ip_freenas/a_share_dataset.
I connect , I can
smb: \> mkdir test5 # to try
I look in log in freenas : tail -f /var/log/samba4/log.smbd , nmbd and others but nothing happens.
What did I miss?
Thanks
FreeNAS-11.2-RC2
/var/log/messages
frouty
OK thanks
I add
log level = 3 passdb:5 auth:5 <------ pour augmenter la verbosité des logs.
in the /usr/local/etc/smb4.conf [global]
And I got enough info to fix my problem.
Is it more interesting to use the full-audit auxiliary parameters?
