unhealthy pool ?
georgelza
Hi all
This morning woke with a meal from my NAS re a unhealthy pool, login in I can see that "bunker" had some problems, if you look at the attached though, am I correct that it sorted itself out... and now how do I get rid of the unhealthy tag?
Note... I did a scrub after seeing this, no errors or problems picked up during scrub.
G
c77dk
There's some checksum errors, which you should take a closer look at. Might be cables/controller/disks - start by checking dmesg and smart (please say you run tests).
Regarding marking clean, it's as simple af "zpool clear bunker"
georgelza
dmesg is clear.
I know I run smart... for the live of me can't find the report option in the menu structure, please advise.
G
Etorix
Just run smartctl -a /dev/daN
