I can however add a new task, but when I try to edit it I get the response below. If I try to edit a previously existing task, the GUI brings up a copy of the current window with the terminal view in it. Pretty odd. If I look at /data/freenas-v1.db with sqlite, the tasks are in the tasks_cronjob table and seem to have all the right fields-values. If I pull a config backup and look at it in a sqlite browser, the tables match. If the config data stored someone else besides the sqlite db?
The system has been updated to FreeNAS-9.10.2-U2 (e1497f2) and restarted. The problem remains.
Thanks,
DAve
Request Method:
GET
Request URL: http://10.16.2.71/admin/tasks/cronjob/edit/None/
Software Version: FreeNAS-9.10.2-U2 (e1497f2)
Exception Type: ValueError
Exception Value:
invalid literal for int() with base 10: 'None'
Exception Location: /usr/local/lib/python2.7/site-packages/django/db/models/fields/__init__.py in get_prep_value, line 613
Server time: Fri, 31 Mar 2017 16:16:35 -0400
Traceback
Environment:
Request Method: GET
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response
105. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view
156. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
22. return view_func(request, *args, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/options.py" in wrapper
208. return self._admin.admin_view(view)(*args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/utils/decorators.py" in _wrapped_view
99. response = view_func(request, *args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/views/decorators/cache.py" in _wrapped_view_func
52. response = view_func(request, *args, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/site.py" in inner
145. return view(request, *args, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/options.py" in edit
484. instance = get_object_or_404(m, pk=oid)
File "/usr/local/lib/python2.7/site-packages/django/shortcuts/__init__.py" in get_object_or_404
113. return queryset.get(*args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py" in get
301. clone = self.filter(*args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py" in filter
593. return self._filter_or_exclude(False, *args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py" in _filter_or_exclude
611. clone.query.add_q(Q(*args, **kwargs))
File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/query.py" in add_q
1204. clause = self._add_q(where_part, used_aliases)
File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/query.py" in _add_q
1240. current_negated=current_negated)
File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/query.py" in build_filter
1131. clause.add(constraint, AND)
File "/usr/local/lib/python2.7/site-packages/django/utils/tree.py" in add
104. data = self._prepare_data(data)
File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/where.py" in _prepare_data
79. value = obj.prepare(lookup_type, value)
File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/where.py" in prepare
352. return self.field.get_prep_lookup(lookup_type, value)
File "/usr/local/lib/python2.7/site-packages/django/db/models/fields/__init__.py" in get_prep_lookup
369. return self.get_prep_value(value)
File "/usr/local/lib/python2.7/site-packages/django/db/models/fields/__init__.py" in get_prep_value
613. return int(value)
Exception Type: ValueError at /admin/tasks/cronjob/edit/None/
Exception Value: invalid literal for int() with base 10: 'None'
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
Variable Value
csrftoken 'Z1DEJvEcai6QXa5FXLzQylz2GXbX6Tsy'
sessionid 'd0qbomyjwfluvrlq84fvgp1wgmzq1p8y'
fntreeSaveStateCookie 'root%2Croot%2F33%2Croot%2F33%2F37%2Croot%2F33%2F52%2Croot%2F173%2Croot%2F27%2F28%2Croot%2F27%2F43%2Croot%2F186%2Croot%2F186%2F196%2Croot%2F186%2F196%2F198%2Croot%2F189%2F199%2F201%2Croot%2F30%2Croot%2F30%2F31%2Croot%2F30%2F46'
META
Variable Value
DOCUMENT_ROOT '/usr/local/etc/nginx/html'
CSRF_COOKIE u'Z1DEJvEcai6QXa5FXLzQylz2GXbX6Tsy'
SERVER_ADDR '10.16.2.71'
wsgi.url_scheme 'http'
rollbar.uuid u'f43ff0db-ad63-4332-85ab-83067c4df371'
SERVER_PROTOCOL 'HTTP/1.1'
wsgi.version (1, 0)
HTTP_CONTENT_TYPE 'application/x-www-form-urlencoded'
QUERY_STRING ''
REQUEST_METHOD 'GET'
SERVER_NAME 'localhost'
HTTP_ACCEPT '*/*'
SERVER_SOFTWARE 'nginx/1.10.1'
wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x8170a4d10>
wsgi.run_once False
wsgi.multithread True
HTTP_HOST '10.16.2.71'
HTTP_ACCEPT_ENCODING 'gzip, deflate'
wsgi.input <flup.server.fcgi_base.InputStream object at 0x8170a0590>
REQUEST_URI '/admin/tasks/cronjob/edit/None/'
DOCUMENT_URI '/admin/tasks/cronjob/edit/None/'
HTTP_USER_AGENT 'Mozilla/5.0 (Windows NT 6.1; WOW64; rv:52.0) Gecko/20100101 Firefox/52.0'
HTTP_COOKIE 'csrftoken=Z1DEJvEcai6QXa5FXLzQylz2GXbX6Tsy; sessionid=d0qbomyjwfluvrlq84fvgp1wgmzq1p8y; fntreeSaveStateCookie=root%2Croot%2F33%2Croot%2F33%2F37%2Croot%2F33%2F52%2Croot%2F173%2Croot%2F27%2F28%2Croot%2F27%2F43%2Croot%2F186%2Croot%2F186%2F196%2Croot%2F186%2F196%2F198%2Croot%2F189%2F199%2F201%2Croot%2F30%2Croot%2F30%2F31%2Croot%2F30%2F46'
CONTENT_LENGTH ''
HTTP_DNT '1'
HTTP_X_REQUESTED_WITH 'XMLHttpRequest'
SERVER_PORT '80'
wsgi.multiprocess False
HTTPS ''
HTTP_ACCEPT_LANGUAGE 'en-US,en;q=0.5'
PATH_INFO u'/admin/tasks/cronjob/edit/None/'
REMOTE_PORT '64453'
SCRIPT_NAME u''
REMOTE_ADDR '10.16.2.219'
HTTP_CONNECTION 'keep-alive'
GATEWAY_INTERFACE 'CGI/1.1'
REDIRECT_STATUS '200'
HTTP_REFERER 'http://10.16.2.71/'
Thanks,
DAve
Request Method:
GET
Exception Value:
Traceback
Environment:
Request Method: GET
Traceback:
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
Variable Value
META
Variable Value
wsgi.version (1, 0)
QUERY_STRING ''
HTTP_ACCEPT '*/*'
wsgi.run_once False
CONTENT_LENGTH ''
HTTP_DNT '1'
SERVER_PORT '80'
HTTPS ''
REMOTE_PORT '64453'
SCRIPT_NAME u''
