I have a non-recommeded config with single disk RAID0 devices on a hardware RAID controller, but I hope you can consider helping.
Is there any options I can tune when there's no write caches on the drive (or controller)?
I get only 30 to 40 MB/s write throughput per drive (simple local test with dd).
I don't have a good battery for the RAID controller at the moment, but if I force the RAID controller's cache, I get 170MB/s per drive. I'd prefer not to use a battery because it's another component to monitor and replace. [If I enable the physical drive's caches, I get 80-90 MB/s, but the RAID controller won't forward the cache flush commands, so that's out of the question]. I've done some testing with vfs.zfs.vdev.async_write_max_active, but it doesn't seem to change much.
I hope someone may have some tips, but if not, I have to try to find a battery, or bite the bullet and buy a proper HBA. I need to get something with PCI3 because I'll be adding SSDs too. I'm in the all too common position where I've stumbled upon some nice enterprise gear, but it's not a perfect fit for ZFS.
CPU: 2 x Xeon CPU E5-2697 v2
RAM: 128 GB DDR4 ECC
HBA: RAID controller MegaRaid 9280-16i4e; single disk RAID0 mode
DISKS 8 x ST1000NM0033 1TB SATA drives (to be replaced with 4 TB spinning SAS drives)
