aeiche
- Nov 27, 2013
Hi Everyone, first post here:
I've been running Freenas 8.3.0 for a while and recently I came across this (after, IIRC, replacing a failed drive):
Is this a problem with the drive, or a problem with the files? Naturally I want to correct this issue. This is RAID-Z1, so having a drive failure would be bad. None of these files are particularly important. The backups are the most important (because they're backups)
Will replacing this drive and resilvering fix this issue? Or am I going to run into it again because it's a file problem?
My familiarity with ZFS is pretty thin, I'm decent at command line stuff, but not an expert by any means.
many thanks
[aeiche@freenas] /# zpool status -v
pool: ZFSPool
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://www.sun.com/msg/ZFS-8000-8A
scan: scrub repaired 0 in 18h14m with 8 errors on Tue Oct 29 06:32:16 2013
NAME STATE READ WRITE CKSUM
ZFSPool DEGRADED 0 0 21
raidz1-0 DEGRADED 0 0 42
ada1 FAULTED 5 6.40M 0 too many errors
gptid/231c9e00-4fdf-11e2-a258-002522b37906 ONLINE 0 0 0
ada0 ONLINE 0 0 0
gptid/b4082b65-fcc4-11e2-8593-002522b37906 ONLINE 0 0 0
/mnt/ZFSPool/Movies/IRON_MAN.m4v
/mnt/ZFSPool/Backups/Aaron- Backup/Aaron iMac Backup.sparsebundle/bands/8673
/mnt/ZFSPool/Backups/Hykel - Backup/Hykel iMac Oct2011.sparsebundle/bands/1275c
/mnt/ZFSPool/Downloads/demo_beaglebone_BBB-eMMC-flasher-2013.06.20.img.xz
/mnt/ZFSPool/Backups/Laurie's iBook Disc/Users/Roo/Music/iTunes/iTunes Music/Compilations/A Knight's Tale/06 Further On Up The Road.m4a
/mnt/ZFSPool/Backups/Laurie's iBook Disc/Users/Roo/Music/iTunes/iTunes Music/Compilations/A Million In Prizes The Anthology [Disc 1]/1-16 Tonight.m4aIs this a problem with the drive, or a problem with the files? Naturally I want to correct this issue. This is RAID-Z1, so having a drive failure would be bad. None of these files are particularly important. The backups are the most important (because they're backups)
many thanks
