TrueNAS shows null for every HDD as temperature
jagdtigger
Hi all!
So i have an issue where if i go to reporting every hdd shows null as temperature. Dropping into SSH and using smartctl the temperature data can be read out from them. I am not a pro so i do not have the foggiest idea where to start so i would appreciate any ideas.
Thanks!
HW info:
4x 10 TB Ironwolf
HP H220 IT mode
truenas inside xcp-ng, hba directly attached to vm via pci passthrough
mauritsl
Is this when the system is just started or even after a day online?
I have seen the same issue but after serveral hours the system started to show the temperature..
Patrick M. Hausen
What does smartctl -a <one disk drive> result in?
jagdtigger
Here you go:
root@zenifer[~]# smartctl -a /dev/da1
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-PRERELEASE amd64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate IronWolf
Device Model:     ST10000VN0004-1ZD101
Serial Number:    <removed>
LU WWN Device Id: 5 000c50 0a30f9e73
Firmware Version: SC60
User Capacity:    10,000,831,348,736 bytes [10.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Oct 14 19:58:20 2020 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (  567) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
recommended polling time:      ( 864) minutes.
Conveyance self-test routine
recommended polling time:      (   2) minutes.
SCT capabilities:            (0x50bd)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   078   064   044    Pre-fail  Always       -       70382448
  3 Spin_Up_Time            0x0003   086   086   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       228
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   094   060   045    Pre-fail  Always       -       2309744868
  9 Power_On_Hours          0x0032   069   069   000    Old_age   Always       -       27848 (1 83 0)
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       97
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       4295032833
189 High_Fly_Writes         0x003a   095   095   000    Old_age   Always       -       5
190 Airflow_Temperature_Cel 0x0022   068   048   040    Old_age   Always       -       32 (Min/Max 24/39)
191 G-Sense_Error_Rate      0x0032   096   096   000    Old_age   Always       -       8205
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       14
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       294
194 Temperature_Celsius     0x0022   032   052   000    Old_age   Always       -       32 (0 23 0 0 0)
195 Hardware_ECC_Recovered  0x001a   033   001   000    Old_age   Always       -       70382448
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0023   100   100   001    Pre-fail  Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       27750 (75 146 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       54852690779
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       195330789909
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%     27782         -
# 2  Short offline       Completed without error       00%     27756         -
# 3  Short offline       Completed without error       00%     27588         -
# 4  Extended offline    Completed without error       00%     27531         -
# 5  Short offline       Completed without error       00%     27420         -
# 6  Extended offline    Completed without error       00%     26627         -
# 7  Short offline       Completed without error       00%     26413         -
# 8  Short offline       Completed without error       00%     25669         -
# 9  Short offline       Completed without error       00%     24949         -
#10  Extended offline    Completed without error       00%     24419         -
#11  Short offline       Completed without error       00%     24037         -
#12  Extended offline    Completed without error       00%     24008         -
#13  Short offline       Completed without error       00%     23319         -
#14  Short offline       Completed without error       00%     22575         -
#15  Extended offline    Completed without error       00%     22262         -
#16  Short offline       Completed without error       00%     21879         -
#17  Short offline       Completed without error       00%     21135         -
#18  Short offline       Completed without error       00%     20391         -
#19  Short offline       Completed without error       00%     19671         -
#20  Short offline       Completed without error       00%     18929         -
#21  Short offline       Completed without error       00%     18209         -
Patrick M. Hausen
Hmm ... weird. I thought, FreeNAS uses SMART to get the data, and speculated something might be blocked by your combination of HBA and backplane ...
beavis3141
Same here. Reporting and dashboard not showing disk temperatures at all. But command smartctl shell command works fine.
floyd71
I have the same problem.
I am using HPE ProLiant Microserver Gen10 Plus (part number P16006-421) and 2 x 6 TB Seagate IronWolf ST6000VN001 HDD recently bought. Boot device is USB connected Verbatim SSD M.2 drive 120 Gb.
So the problem is similar
In Reporting for Disk, from time to time I got information (temperature) either for this USB drive and both HDD, but many times I have for tempertarue for devices /dev/ada0 and /dev/ada1 just values "null".
If i use "zoom minus" i am getting sometimes values, but in scale that is not very usefull.
Does anyone know if there is trick to show correct temperature.
Also, results of the SMART tests are pretty poor.
I have recently used Nas4FREE (currently it is xigmaNAS) and it works perfectly, and report for devices is much more detailed than in TrueNAS, I guess it could be improved.
floyd71
After some time, I found where is the problem.
HDD temperatures will be properly shown, only in case if you decide to "burn" your HDDs running them all the time, without spin off or standby mode.
In such case, temperature will be shown well.
By my opinion, it is problem with Operating System then (from my recent experience with XigmaNAS it works fine regardless the chosen configuration and SMART reports are much more detailed).
If someone knows how to address issue to TrueNAS developers, it would be good way to go on.
Patrick M. Hausen
Andybluejay
I saw this issue today on TrueNAS-SCALE-22.02.2.1. All drives reporting null after reboot. Running smartctl manually on my first device brought all the info back online.
Revamp
@Patrick M. Hausen
@jagdtigger
Afternoon All,
I know this is an old post but I have the same issue and yes as soon as I have run smartctl against a couple of my drives ( Nvme0n1 and sda ) the reporting came to life..
I have an admin account and run smartctl as Sudo in shell.
I have also noted that none of the HDD temperatures are displayed though if you choose them in the report column drop down just a blank space.
My specs are below in the usual place.
Anybody know of an update on this issue?
TIA
Revamp
Revamp
@Patrick M. Hausen
@jagdtigger
PS... Sorry forgot to say that when I run it as Sudo I still have to type my password as it is request immediately after my first entry then after that I can run it again while in the same shell session but something if I leave the shell session up and try again it request my password again.
I guess it have a session limitation with no activity protection in place.
The reason Im telling you this is I think I set up ( I will double check ) Sudo as a given privilege so I did have to type it. Maybe this is a permissions issue thing with running an object especially for the reports to display correctly.. iHowever, I might be barking up the wrong tree..
TOS5.x TerraMaster Convert to TrueNAS - My system is a fresh build as two days ago..
Any idea of what's happening with this would be good to know..
TIA
Revamp
Patrick M. Hausen
Is there an issue on JIRA? That's where you might get an update from the developers. If there isn't, please create one. This is the community forum. I have no idea.
jagdtigger
@Revamp
Had an inexplicable slowdown issue with it not so long after this i think, wiped xcp-ng and gone bare metal. And a few weeks ago i jumped over to scale so i cant really help... :(
Revamp
I have been away out of France, so I know it is late but thank you for your reply, I'll take a look and raise a ticket if needed..
Revamp
Revamp
@Revamp
No worries.. :smile:
I have been away out of France, so now i'm back I know it is late but thank you for your reply..
Revamp
