Is there a solid resource on working with encrypted datasets in TrueNAS that anyone can point to?
Non-encrypted datasets work just fine - but I can't seem to get it to work for encrypted datasets, receiving the error:
Destination dataset 'Tank-01/01-01' already exists and is it's own encryption root. This configuration is not supported yet. If you want to replicate into an encrypted dataset, please, encrypt it's parent dataset.
In my case ... Prior to migrating to TrueNAS, both TrueNAS-01 & -02 (then "FreeNAS") had legacy GELI-encryption and I had no issue seeding replication and then handing over to the GUI for management, as needed. See Figure 1, below for general schema, adapted to TrueNAS. See Figure 2, below for seed commands.
Now with TrueNAS, I've attempted to utilize a similar schema, but I've had no luck. On both instances, the pool does not have encryption, but Tank-01/01-01 on TrueNAS-01 is encrypted, and similarly I would like the corresponding dataset on -02 to be encrypted as well.
I've poked and prodded ... and attempted to find the answer myself, to no avail. Can anyone provide a much needed hand here, please?
FIGURE 1. REPLICATION SCHEMA
FIGURE 2. REPLICATION SEEDING
TrueNAS      DIRECTION   TrueNAS      Incremental  Seed          Comment
-01          (=> or <=)  -02          Task         Task
  Tank-01                  Tank-01    N/A (Pool)   N/A (Pool)
    01-01        =>          01-01    Inc_Task-01  Seed_Task-01  01-01 & 01-01 both encrypted DS with passphrase
      DS_01                    DS_01  Inc_Task-01  Seed_Task-02
      DS_02                    DS_02  Inc_Task-01  Seed_Task-03
    01-02        =>          01-02    Inc_Task-02                Not encrypted
    02-01        <=          02-01    Inc_Task-03                02-01 & 02-01 both encrypted DS with passphrase
    02-02        <=          02-02    Inc_Task-04                Not encrypted
for clarity, via #zfs list
NAME                 ...  MOUNTPOINT
Tank-01                   /mnt/Tank-01
Tank-01/01-01             /mnt/Tank-01/01-01
Tank-01/01-01/DS_01       /mnt/Tank-01/01-01/DS_01
Tank-01/01-01/DS_02       /mnt/Tank-01/01-01/DS_02FIGURE 2. REPLICATION SEEDING
Seed_Task-01  zfs send Tank-01/01-01@SNAP-YYYY-MM-DD_HH-MM | mbuffer -s 128k -m 1G -O <TrueNAS-02 IP>:9001
              mbuffer -4 -s 128k -m 1G -I 9001 | zfs receive -F Tank-01/01-01
Seed_Task-02  zfs send Tank-01/01-01/DS_01@SNAP-YYYY-MM-DD_HH-MM | mbuffer -s 128k -m 1G -O <TrueNAS-02 IP>:9002
              mbuffer -4 -s 128k -m 1G -I 9002 | zfs receive -F Tank-01/01-01/DS_01
Seed_Task-03  zfs send Tank-01/01-01/DS_02@SNAP-YYYY-MM-DD_HH-MM | mbuffer -s 128k -m 1G -O <TrueNAS-02 IP>:9003
              mbuffer -4 -s 128k -m 1G -I 9003 | zfs receive -F Tank-01/01-01/DS_02
