Transmission 2.90 Upgrade (Because of Malware)
Yatti420
I didn't know freenas was based on macosx.. If you run a mac you should update above 2.90.. They may bump all other versions but who knows..
If your worried about speed of releases install the port instead of a pbi package...
Joshua Parker Ruehlig
2.93 doesn't exist at the moment, it looks like 2.92 is the latest version.
the freenas PBI that I built from source doesn't include malware (unlike the osx version). I looked at the changelog not much has been fixed for freebsd compared to 2.90
stillka
any idea why 2.90 version always overwrite umask to 18? I stop all transmission daemons, modify the settings.json file but after I start it back online umask is back to default!
Rest of settings preserve....
Thank you!
- daemon is stopped, I set umask to 0:
root@transmission_1:/ # ps aux | grep transmission
root 158 0.0 0.2 192456 25716 ?? IJ Sun02PM 0:51.13 /usr/pbi/transmission-amd64/bin/python2.7 /usr/pbi/transmission-amd64/control.py start 192.168.1.20 12346
root@transmission_1:/ # grep umask /var/db/transmission/settings.json
"umask": 0,
- I start daemon UP and umask is re-set to 18..
transmission 82493 1.6 0.1 74636 8728 ?? SsJ 11:39AM 0:00.02 /usr/pbi/transmission-amd64/bin/transmission-daemon -g /var/db/transmission -x /var/run/transmission/daemon.pid
root 158 0.1 0.2 192456 26096 ?? IJ Sun02PM 0:51.28 /usr/pbi/transmission-amd64/bin/python2.7 /usr/pbi/transmission-amd64/control.py start 192.168.1.20 12346
"umask": 18,
Thank you!
"umask": 0,
"umask": 18,
Don't edit this particular settings directly. I tried to make this one easier to change by making it available in the freenas webui and more human readable.
Instead go to FreeNAS WebUI > lef panel > Plugins > Transmission, and change the Permission setting.
trosso
I know of one tracker that banned all Transmission 2.90 clients due to the OSX malware issue, despite there being no issues on other platforms. It'd be nice to have the plugin updated to 2.92, only so that it works with trackers that have stringent client rules. Not a big deal though, I'm using another client in the meantime.
Goobz
I have a few trackers implementing a similar policy and therefor the current 2.90 install in my plugin jail is currently being rejected. This is in turn, screwing up all my automated programs (sonarr, cp etc.).
If it's not too much work can we have an update to 2.92? If not is there an easy way to downgrade without having to re-set up all my seeds?
Thanks so much I appreciate your hard work!
Goobz
Thanks for that link. I'll save it for later. I'll hold out on downgrading if you are going to look at it in the next few days. Nothing urgent. Thanks again mate!
transmission 2.92 should be available from the freenas repo now
sure, thanks for informing me. I'll try updating it tonight if I have a chance
I built the update and uploaded it to my local repo, but for some reason it crashed last night before the official repo could pull the update. hopefully it wont happen again, and the update will be available tomorrow.
I built the update and uploaded it to my local repo, but for some reason it crashed last night before the official repo could pull the update. hopefully it won't happen again, and the update will be available tomorrow.
would it be possible to get an update to 2.94? some of my private trackers are doing away with support for TLS 1/1.1 & only supporting TLS 1.2+... though I'm not sure if this update will make TLS 1.2 work...? maybe updating OpenSSL in the plugin jail?
