First time FreeNas user, and first post here.. Please go easy on a Newbie :)
I currently have a UnRaid setup that I'm using for my Home NAS. Now, I'v recently setup a FreeNas machine that I would like to use a backup solution. (To be specific, both machines are VM on Esxi with an separate HBA cards for passthrough of storage disks)
Now, I'm faced with 2 things to do.
1. First Transfer all data from Unraid onto the FreeNas Machine.
2. Setup some type of scheduler to continuously sync the two machines together on a nightly/weekly, or some other schedule. I don't add to much on a daily basis, so the scheduling is still is to be decided.
I know both Unraid and FreeNas have rsync already installed. And I think the best approach is to 'push' the data from Unraid to FreeNas?
But I may also wish to one day reverse the situation, by making FreeNas the main NAS, and Unraid as the backup. So in that case, I would likely want to 'push' from FreeNas to Unraid.
I think its likely best to try to mount each share on the other machine? And then use rsync to transfer the data?
If someone can post any examples of
1. How to mount an external CIFS or NSF share on FreeNas, and
2. How to both a 'push' and 'pull' from one machine to another.
3. If possible how you would set it up to auto sync on a schedule, I guess via some kind of cron job?
I know just enough about linux, ubuntu, etc to be 'dangerous', where I'm not afraid to try something, albiet at a risk of hosing the machine and having to do a fresh re-install :P
Any help is appreciated.
Thanks
PT
Thanks
PT
