Tips to improve performance in low very low spec system?
Rarokillo
Hello before anyone says anything about it: YES, my hardware is TOO low specs.
My system is:
Intel Atom D525 @ 1.80GHz
4GB of RAM
2 USB docks with 4x3TB each one.
RAIDZ 2 with 8 disks
Using FTP the speed is about 15MB/s it's not the best in the world but I'm using it mainly as a storage for backups so I can live with it.
The trouble is that when I connect to it from Windosws 10 using CIFS the speed is too unstable. Sometime it goes at 15MB/s and suddenly it goes down to 0MB/s, and then suddenly 20MB/s and then falls to 5MB/s.
I know that with my specs It will always be slow as hell but: Is there anything that I can do with the settings that could give a more stable speed?
Jailer
Not strong, but bad
It's not that your system is low spec, its below minimum specs. And far below minimum at that.
Bidule0hm
Server Electronics Sorcerer
This thread is good candidate for this one I guess :)
anodos
Sambassador
My system is:
4GB of RAM
The cheapest solution is to buy a T20. Failing that, perhaps look into installing centos with no GUI and installing / configuring samba. The centos 6.x branch is nice, stable, and trouble-free.
Oh, and get a case that has enough space to accommodate all those drives. Your USB storage array is a terrible idea.
Jailer
Not strong, but bad
SweetAndLow
Sweet'NASty
Install different operating system. Freenas is not for you. Kind of like asking why my motorcycle is so slow when I'm in the lake. Wrong tool for the job.
anodos
Sambassador
raulfg3
as other users says, perhaps you need to test other options like:
1 - Nas4Free for ZFS support (Use BSD for OS base)
2 - OMV that use Debian LINUX for OS. Base (support ZFS using OPENZFS)
anodos
Sambassador
Actually, the requirements for freenas+zfs and Nas4Free+zfs are basically the same. The point is that with an atom D525, you're probably best off avoiding zfs entirely.
That said, the system as designed has a fundamental flaw that cannot be worked around - the array is composed of USB drives. No OS change is going to fix this.
korrupto77
Mate, i can understand your desire to build something on your own and maybe re-use some part... But below the minimum requirement system is unstable and you could not trust to store your precious data on it... Specially in term of ram ...
Inviato dal mio iPhone utilizzando Tapatalk
