This morning I upgraded both of my TrueNAS Scale machines to 22.12.2. My primary machine upgraded without issue, but reporting is broken on my on-site backup server. I tried manually restarting services as suggested in another thread here, which indicated that /etc/collectd/collectd.conf did not exist. I copied the file from my working machine, which allowed the service to start, however reporting was still broken. Further investigation showed that my system dataset wasn't mounted. It mounts if I manually select it via System Settings > Advanced > Storage, but the change doesn't survive a reboot. At approximately the same time I noticed that swap is also failing to mount at boot, and I haven't been able to resolve that thus far. Selecting the 22.21.1 boot environment likewise does not resolve the issue.
I see the following errors during boot, or via sudo journalctl -xe:
Failed to start Configure swap filesystem on boot pool.
Failed to start Import ZFS pools.
Hardware of affected system:
SCALE 22.12.2
Intel Xeon E3-1220L
SuperMicro X9SCM-F
8GB ECC
Boot: 2x Samsung MZ-7LN128HAHQ PM871B 128GB - Attached to MB SATA ports as dev/sda & /dev/sdb, mirrored
Storage: 2x Samsung HD204UI 2TB - Attached to HBA as dev/sde & /dev/sdf, mirrored
HBA: LSI 9207-8i
The boot pool drives have a 16GB swap partion each, but I don't believe they've been used; AFAIK the system swap partitions are on the storage drives. I also have a pair of 6TB WD Red Pros in the system that are currently unused.
SCALE 22.12.2
Intel Xeon E3-1220L
SuperMicro X9SCM-F
8GB ECC
HBA: LSI 9207-8i
