Syba 10Gbe Card for $89
Yorick
What are you using as a 10Gb switch?
Jessep
Used enterprise gear can be had for much cheaper and will have much greater driver/OS support.
You don't need a switch for small setups as you can use PtP with DAC or fibre.
Otherwise please report back with support/stability/driver update frequency with your OSs of choice.
Ender117
A T420-CR can be had for 40 from eBay, that is about one of the best card for FreeNAS
microserf
  • 20180706_Linux_2.0.15.0.zip
