jstillwa
- Jan 24, 2013
So this thread (http://forums.freenas.org/showthread.php?6254-Replacing-Hard-Disk-swap-partition-question) seems to indicate that the default use of 2GB, or what have you, swap partition on the system will cause the system to crash in the event of the drive failure. This seems to be the cause for our system, as our system has been crashing/freezing on drive failures and that does not seem the default behavior as reported on the forum. Is it the actual case that the default method of FreeNAS of striping swap across the drives in the system means that if one of those drives fail, the system can't potentially can't access the swap space and dies?
