SuperMicro X11SCH - irq9: acpi0 heavy interrupts, kernel (pid 0) constant ca. 30% cpu usage
f00b4r0
I'm new to FreeNAS/FreeBSD (coming from a Linux background). I have noticed that the CPU would remain under near permanent 30-36% "system" load on my fresh install of 11.2-U2.1. Digging a bit more it appears this comes from the "kernel" task (showing in top -PS).
Worried I might have done something wrong I booted a clean USB installer, started a shell and checked the output of "ps faxlr", only to notice the exact same issue, with the kernel being the second task listed and consistently using a third of the total elapsed time. MWCHAN says "swapin", STAT is "DLs".
Hardware is as follows:
  • motherboard make and model: Supermicro X11SCH-LN4F
  • CPU make and model: Intel Celeron G4900
  • RAM quantity: 16GB ECC
Is this a known problem? Is there a fix?
The side problem is that this keeps the CPU busy and that shows on the idle power usage and average temperature...
Thanks
f00b4r0
Did a bit more investigation, it seems this usage is related to a very high rate of acpi0 interrupts:
[root@freenas /]# vmstat -i
interrupt                          total       rate
irq9: acpi0                     85001055      10059
cpu0:timer                       9518921       1126
cpu1:timer                       9518383       1126
irq264: xhci0                     396885         47
irq265: ahci0                      29897          4
irq266: igb0:que 0                312900         37
irq267: igb0:que 1                 81829         10
irq268: igb0:link                      2          0
Total                          104859872      12409
f00b4r0
OK so after a little more investigation it turns out this is indeed related to the irq storm on IRQ9 (acpi0). The same problem shows up in Linux, where the details in /proc/interrupts show that this only affects the first cpu core. So that's not a FreeNAS-specific problem.
FWIW I tried all sorts of BIOS settings to no avail, and I also checked I'm running the latest BIOS for this board.
ukn
Did you find out anything new?
I noticed the same here on a X11SCH-LN4F with i3-8100.
Latest BIOS (X11SCH8_928.zip), latest FreeNas (11.2-U2.1).
Cyb3rfr3ak
This BIOS update fixed that issue for me (Board: X11SCH-LN4F, CPU: Intel Core i3-8100).
According to Supermicro support, this release candidate can contain minor bugs.
Release date is not set but it should be in the next couple of weeks.
  • x11sch9.306-RC.zip
Considering that their release versions are typically riddled with bugs inherited from AMI, that doesn't seem like a very bad thing.
f00b4r0
Tested, it does fix the problem here too. Thanks!
Epism
Welp, I came across your issue after looking into mine... I have the X11SCH-F, and also IRQ9/ACPI is out of control. Going to contact SM and see if they have an update I can use.
Liriel
I am looking at getting a X11SCH-F.
For folks having the IRQ storm issue, was there ever a non-release candidate BIOS update that fixed the issue? Any other issues with this MB?
