Macaroni323
 - Oct 8, 2015
I have a pool that I've just expanded to 3 VDevs of 2 x 4TB mirrored disks each for a total of 12TB.  I have come into 2 8TB disks and I'd like to change one of the VDevs from 2 v4TB into 2 x 8TB and save the 4TB disks as backups for the 4TB mirrors (two are very old so...).  I want to know if it is possible to pull a 4TB disk from one of the 2 x 4TB mirrors, replace with an 8TB, allow the system to resilver (probably at 4TB of the 8TB if it is possible), after the resilvering replace the remaining 4TB disk mirrored with the 8TB with the other 8TB and resilver (probably resulting in a 2 x 8TB partitioned only to 4TB mirror).  After all is stable I'd like to expand the partition.
Is this feasible?
			Is this feasible?
