Storage capacity after Replication Question?
jay.ing
I followed this guide -
https://forums.freenas.org/index.ph...te-data-from-one-pool-to-a-bigger-pool.40519/
as ive just installed 4 X4TB dives in RAIDZ1 configuration.
My question is why is there a size miss-match from the old to the new?
Thanks
jay.ing
Replication is now complete and all data has been copied to the new volume, there is now a 76.74Gig difference between pools with the exact same data on. Is this because the old volume was mirrored and the new volume is RAIDZ1?
droeders
Yes - this is most likely the reason for the size difference. I noticed something similar on data that was replicated between pools with different layouts.
I was overly paranoid about it, and went so far as to compare checksums of all my files.
