junior466
- Mar 26, 2018
Today one of my hosts that use a SMB share to backup some files failed to run and upon checking the logs in freenas, I found this:
The messages didn't stop until I restarted the smbd service. Unfortunately it's not the first time it has happened.
Running FreeNAS-11.2-U8.
edit.
Here's the content of /var/log/samba4/log.smbd
edit 2 - It seems that disabling hostname lookups under smbd configuration can help?
pid 19878 (smbd), uid 0: exited on signal 6 (core dumped)
pid 98451 (smbd), uid 0: exited on signal 6 (core dumped)
pid 98473 (smbd), uid 0: exited on signal 6 (core dumped)
pid 98474 (smbd), uid 0: exited on signal 6 (core dumped)
pid 98482 (smbd), uid 0: exited on signal 6 (core dumped)
...goes on..
edit.
[2021/03/25 19:23:18.479915, 0] ../source3/smbd/server.c:1754(main) smbd version 4.9.18 started. Copyright Andrew Tridgell and the Samba Team 1992-2018 [2021/03/25 19:23:18.482253, 1] ../source3/profile/profile_dummy.c:30(set_profile_level) INFO: Profiling support unavailable in this build. [2021/03/25 19:23:18.729678, 1] ../source3/smbd/files.c:227(file_init_global) file_init_global: Information only: requested 1412579 open files, 59392 are available. [2021/03/25 19:23:18.733297, 0] ../lib/util/become_daemon.c:136(daemon_ready) daemon_ready: daemon 'smbd' finished starting up and ready to serve connections [2021/03/25 19:23:20.060014, 0] ../source3/lib/util_sock.c:875(matchname) matchname: host name/name mismatch: 192.168.139.25 != (NULL) [2021/03/25 19:23:20.060131, 0] ../source3/lib/util_sock.c:1054(get_remote_hostname) matchname failed on 192.168.139.25 [2021/03/25 19:47:25.144005, 0] ../source3/lib/util_sock.c:875(matchname) matchname: host name/name mismatch: 192.168.139.25 != (NULL) [2021/03/25 19:47:25.144140, 0] ../source3/lib/util_sock.c:1054(get_remote_hostname) matchname failed on 192.168.139.25
