nielsd
- Apr 22, 2022
Hi Dears,
i try to install current stable TrueNAS 12 on a HP DL360 Gen 10 with
Intel(R) Xeon(R) Silver 4208 CPU @ 2.10GHz and
HPE Smart Array P408i-a SR Gen10 HBA (with latest firmware 4.11)
4 x 2.4 TB HPE disks (with firmware HPD6)
The HBA is "unconfigured" (means HBA mode?) - all attached disks are used in ZFS
Installation works well, but if i try to do some interaction like installing packages in jails, console throws errors and the process stucks unkillable - this renders the whole system instable/unsusable after that. Just a hard reset then works.
ERROR:
beside this, i can see several lines in dmesg from time to time (smartd is disabled)
ERROR:
to what i've found in the FreeBSD space, the error seems related to the smartpqi driver - it seems the bug is related to the FreeBSD smartpqi driver:
www.mail-archive.com
is there any chance to get a current driver backported to TrueNAS 12 or - if not - in the upcoming 13 version?
Or does anyone any workaround so far?
If i'm right, this should be this:
Many thanks for your time,
niels.
ERROR:
[CPU 7][pqi_map_request][540]:bus_dmamap_load_ccb failed = 36 count = 131072
ERROR:
[CPU 2][os_aio_response_error] SCSI_STATUS_CHECK_COND sense size 36
[Bug 257890] Storage controller lockup on zfs scrub [smartpqi][zfs]
niels.
