Slow CIFS/FTP Transfer
epicfatigue
Hey Guys,
My First post here been using FREENAS for about a year now and love it!
I have always had very slow CIF transfer speeds of around 10MB per second,
FTP Transfers about the same speed aswell.
However if i copy from the NAS from one location to another i get around 135MB per second.
My specs are (Please don't laugh hahah its a low powered media server)
Intel(R) Celeron(R) CPU J1900 1.99GHZ Quad core
8GB DDR3 (I know i really should have more)
5x 2TB Drives running Raidz1-0
Fully wired GB Network.
Im Not sure what logs to provide.
Thanks all for reading.
epicfatigue
How come my internal transfer is so fast?
I cant see the cpu maxing out or memory, what things can i look into?
With Windows installed i see a much faster transfer?
pirateghost
Unintelligible Geek
Uh. Internal transfer inside the NAS doesn't use any network interface at all.
Windows supports a crappy realtek NIC, freebsd doesn't.
This isn't rocket surgery.
epicfatigue
I Would love to say what i really think here but since my lack of knowledge on FREEBSD and two riveting responses i finally have something i can kind of work with here.
If it is a lack of supporting a network card, i can simply put in a server grade NIC.
I believe its "rocket science" as surgery takes place in a medical facility.
Now i am simply in the Help and Support as that's kind of what i thought this forum was, but what i have really received was "Your a bloody idiot please $%& off"
Can we please recover from this and point me in the trouble shooting steps for finding what the bottle neck is?
Is there a supported method for stress testing a NIC to see if there is another limiting factor?
There is nothing to troubleshoot. The problem is your inadequate hardware.
pirateghost
Unintelligible Geek
You've been told it's your crappy hardware (mainly the NIC, but the motherboard choice isn't something to write home about).
You also never mentioned what your server is connected to. If you're connected to a 100mb switch/router, you will never see much better than what you are now.
PS, if you're really trying to correct me on the rocket surgery line, you have failed to grasp simple humor. Congratulations.
gpsguy
Active Member
As pirateghost said, you haven't told us anything about the rest of your hardware either. While you might have a "Fully wired GB Network", you could still have a bad cable or two in the mix.
What are the spec's of the client machine? Does it have spinny rust or a SSD?
Also, how full is your pool? How fragmented?
No need for a server class NIC. An Intel Pro/1000 CT (~$30 USD) is fine.
epicfatigue
All i was simply saying is the answers were not overly informative or helpful.
I think we can all agreed we are aloud a shit day every-now and then, and i am not saying i am not thankful for people taking their time out to reply and help i just couldn't get a lot out of it as the answered were very short.
The NAS is not something that is ment to be super Powerful it is simply a download client that streams to my children machines, however a Quad core in my eyes running at 98% idle should have been capable of a better through put.
I am not an expert and i am wanting to learn more as i really have enjoyed configuring and using this product.
But i am also attempting to keep my electricity footprint to a minim.
So i will say Thank you Ericloewe, pirateghost and gpsguy, as i want you to know i am thankful.
The Nas is directly connected to a standard Netgear gigabit router/switch all cables are tested and working fine.
However i do have a L2 Cisco managed switch with a fiber router ready to go, but i can not set this up untill the person i brought my house from stops squatting in it and i can actually move in.
The client machine is a x79 octa core 32 gigddr4 and PCI-E SSD
My Disk Usage is sitting at 89% because i haven't purged in awhile, however the transfer speed has been low before then.
NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROO
Raid 9.06T 8.12T 967G - 28% 89% 1.07x ONLINE /mnt
freenas-boot 29G 1.88G 27.1G - - 6% 1.00x ONLINE -
Took alot of looking to find out how to check for fragmentation, i found it in a book called: Learning FreeNAS by Gary Sims
What caused Fragmentation and what is an except able amount
Would this network card be okay?
http://www.scorptec.com.au/product/...MmKSTF8zHZydhKx9dGotSo6flC2W72RrpghoCiGXw_wcB
epicfatigue
Hey Guys,
So i have ad to wait for the card to be ordered in and it has arrived.
I have read as much as i can through posts and just chasing a little bit more advice.
I am running FreeNAS-9.3-STABLE-201501212031
I have upgraded to an Intel EXPI9301CTBLK gigabit controller.
I added the following to CIFS Service
ea support = no
store dos attributes = no
map archive = no
map hidden = no
map readonly = no
map system = no
I Have tested using IPERF
Client connecting to 192.168.0.13, TCP port 5001
TCP window size: 32.5 KByte (default)
[ 3] local 192.168.0.254 port 36375 connected with 192.168.0.13 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-100.0 sec 1.09 GBytes 93.9 Mbits/sec
[ 3] 100.0-200.0 sec 1.09 GBytes 93.8 Mbits/sec
[ 3] 200.0-300.0 sec 1.09 GBytes 94.0 Mbits/sec
[ 3] 0.0-300.0 sec 3.28 GBytes 93.9 Mbits/sec
[admin@freenas ~]$ iperf -c 192.168.0.13 -p 5001 -t 600 -i 200
[ 3] local 192.168.0.254 port 49721 connected with 192.168.0.13 port 5001
[ 3] 0.0-200.0 sec 2.19 GBytes 93.9 Mbits/sec
I Also tried it in the other direction to test both TX and RX speeds
The CPU doesn't appear to be overworked
I have alto attached my samb4 config
I am alittle lost as where to go from here any help would be appreciated
  • samb4.txt
Clearly, one of the links is running at 100Mb/s. Fix that.
epicfatigue
Eric you sir are a champ it appears after installing the network card I have pinched the network cable in the server cabinet door.
Replaced it and i am now running at 672 Mbits/sec from a short iperf test.
And now 117mb transfer from CIFS!
That realtek nic was a complete hunk of crap!
Thanks everyone for your help, i have learnt alot about FREENAS and my machine is now humming!
gpsguy
Active Member
Thanks for following through with our suggestion to replace the NIC. As you've now learned, the Realtek's might be okay for Windows, but they are RealCrap on FreeNAS.
epicfatigue
I certainly have, next step is to get Zoneminder installed and working in a Jail.
Thats why i needed more bandwidth on the nic.
SweetAndLow
Sweet'NASty
Just a heads up but something is still wrong. Your speeds are still very slow. With Intel NICs you should be getting 900+Mbps.
Eh, iperf with default settings sometimes struggles. I generally run two to four connections to get a proper idea of what the network is capable of.
SweetAndLow
Sweet'NASty
Interesting, I always get max throughout.
