guermantes
- Sep 27, 2017
So I replicated my snapshots of
Briefly during the Replication task process, in which the task was actually replicating two datasets
			/mnt/TANK/dev to /mnt/OFFSITE-GREEN/backup/dev. The number of files and directories in source and destination are the same. The number of "dev snapshots" are the same. The compression and record sizes are the same for both datasets. But there is a large discrepancy in the disk usage sizes. What might that be due to? Briefly during the Replication task process, in which the task was actually replicating two datasets
dev and sysadmin, I saw the orange Running button flicker into a red Error button and then becoming orange again. Code:
root@freenas:~ # ls -R /mnt/TANK/dev | wc -l 309640 root@freenas:~ # ls -R /mnt/OFFSITE-GREEN/backup/dev | wc -l 309640 root@freenas:~ # du -s /mnt/TANK/dev 11684743 /mnt/TANK/dev root@freenas:~ # du -s /mnt/OFFSITE-GREEN/backup/dev 10660803 /mnt/OFFSITE-GREEN/backup/dev
