SOLVED SID does not resolve after reinstall
arkoMax
I had to reinstall FreeNAS onto a new USB drive as my previous one kept being dismounted every so often (at least I truly hope that it was due to a faulty stick and not a bigger problem with my system).
In any case, saved the config earlier in the day, did a fresh install of FreeNAS onto a new drive, re-imported, and I am back up and running. Everything seems to be in order within the FreeNAS GUI and I have no problems with my shares as previously configured.
However - right clicking any of the shares/files and looking at the windows security properties, the owner group is properly enumerated but the owner user isn't ... it's showing Account Unknown and the SID. The owner user is the same as what I am logged on as in windows. The dataset permissions (and my created users/groups) in the FreeNAS GUI all look normal as before.
Any ideas on how I can fix this?
What does Windows' permissions manager show?
arkoMax
Hi Eric, please see below
[root@KNOX ~]# getfacl /mnt/VOL1/media
# file: /mnt/VOL1/media
# owner: myst
# group: admin
			owner@:rwxpDdaARWcCos:fd-----:allow
			group@:rwxpDdaARWcCos:fd-----:allow
		 everyone@:r-x---a-R-c---:fd-----:allow
[root@KNOX ~]#
What versions of FreeNAS are we dealing with here?
arkoMax
Post output of net getlocalsid along with version of FreeNAS you were running before the upgrade / reinstall.
[root@KNOX ~]# net getlocalsid
Environment LOGNAME is not defined. Trying anonymous access.
SID for domain KNOX is: S-1-5-21-2239474815-3528616346-3593154525
FreeNAS version is 11.0-U2, before and after reinstall (this is a new system, few weeks old).
anodos
Sambassador
Run the following commands:
net groupmap list
net usersidlist
pdbedit -Lv myst
Post contents of /usr/local/etc/smb4.conf
Perhaps send me a PM with a debug tarball. I'd like to look at this closer since it appears that your local domain's SID changed (which it shouldn't do).
arkoMax
net groupmap list
net usersidlist
pdbedit -Lv myst
[root@KNOX ~]# net usersidlist
KNOX\myst
S-1-5-21-2239474815-3528616346-3593154525-1002
S-1-1-0
S-1-5-2
S-1-5-11
I am completely new to unix, how do I read the contents of smb4.conf?
I tried just running /usr/local/etc/smb4.conf and get bash: /usr/local/etc/smb4.conf: Permission denied
Edit: I just noticed in the quote above that there is another command "pdbedit"..but it does not appear in your comment above anodos? not sure if I should run that or not..
anodos
Sambassador
KNOX\myst
S-1-1-0
S-1-5-2
S-1-5-11
An easy way to get it is to type cat /usr/local/etc/smb4.conf and press enter. If you want to be able to scroll around the file with arrow keys and PgUp / PgDn, then type less /usr/local/etc/smb4.conf. When you are done looking at it via less, then press the "q" key.
Please post the output of pdbedit -Lv myst.
arkoMax
Thanks for explaining, and for your patience. Here it is:
[global]
	server max protocol = SMB2
	encrypt passwords = yes
	dns proxy = no
	strict locking = no
	oplocks = yes
	deadtime = 15
	max log size = 51200
	max open files = 941141
	logging = file
	load printers = no
	printing = bsd
	printcap name = /dev/null
	disable spoolss = yes
	getwd cache = yes
	guest account = nobody
	map to guest = Bad User
	obey pam restrictions = yes
	ntlm auth = no
	directory name cache size = 0
	kernel change notify = no
	server string = KNOX SERVER
	ea support = yes
	store dos attributes = yes
	lm announce = yes
	unix extensions = no
	time server = yes
	acl allow execute always = true
	dos filemode = yes
	multicast dns register = yes
	domain logons = no
	local master = yes
	idmap config *: backend = tdb
	server role = standalone
	netbios name = KNOX
	workgroup = WORKGROUP
	security = user
	pid directory = /var/run/samba
	create mask = 0666
	directory mask = 0777
	client ntlmv2 auth = yes
	dos charset = CP437
	unix charset = UTF-8
	log level = 0
[Archive]
	path = "/mnt/VOL2/archive"
	printable = no
	veto files = /.snapshot/.windows/.mac/.zfs/
	writeable = yes
	browseable = yes
	vfs objects = zfs_space zfsacl streams_xattr aio_pthread
	hide dot files = no
	guest ok = no
	nfs4:mode = special
	nfs4:acedup = merge
	nfs4:chown = true
	zfsacl:acesort = dontcare
[Media]
	path = "/mnt/VOL1/media"
	printable = no
	writeable = yes
	browseable = yes
	hide dot files = yes
	guest ok = yes
	nfs4:mode = special
	nfs4:acedup = merge
	nfs4:chown = true
[Media2]
	path = "/mnt/VOL1/media2"
	printable = no
	writeable = no
	browseable = yes
	hide dot files = no
	guest ok = no
	nfs4:mode = special
	nfs4:acedup = merge
	nfs4:chown = true
[root@KNOX ~]# pdbedit -Lv myst
Unix username:		myst
NT username:
Account Flags:		[U		  ]
User SID:			 S-1-5-21-2239474815-3528616346-3593154525-1002
Primary Group SID:	S-1-5-21-2239474815-3528616346-3593154525-513
Full Name:			myst
Home Directory:	   \\knox\myst
HomeDir Drive:
Logon Script:
Profile Path:		 \\knox\myst\profile
Domain:			   KNOX
Account desc:
Workstations:
Munged dial:
Logon time:		   0
Logoff time:		  9223372036854775807 seconds since the Epoch
Kickoff time:		 9223372036854775807 seconds since the Epoch
Password last set:	Sat, 19 Aug 2017 04:16:13 AEST
Password can change:  Sat, 19 Aug 2017 04:16:13 AEST
Password must change: never
Last bad password   : 0
Bad password count  : 0
Logon hours		 : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
arkoMax
Post output of getfacl /mnt/VOL1/media/Movies.
[root@KNOX ~]# getfacl /mnt/VOL1/media/Movies
# file: /mnt/VOL1/media/Movies
# owner: myst
# group: admin
			owner@:rwxpDdaARWcCos:fd----I:allow
			group@:rwxpDdaARWcCos:fd----I:allow
		 everyone@:r-x---a-R-c---:fd----I:allow
arkoMax
Just noticed this - no problem, but please let me know how exactly to do this..
Edit: Never mind, figured it out from the manual, sent you the debug log.
arkoMax
Just an update for closure - the owner group is now enumerating properly. I didn't do anything myself, just randomly checked today and saw that it's working. Can't explain as to why :confused:
