Shutdown After 30 Min
ThomasTaylor
my FreeNAS runs after Boot for 30 minutes before it goes down on its own, i have no Idea why, i checked my logs and found this.
Does somebody has any idea?
Samuel Tai
Details of your hardware please, and the version of FreeNAS involved. As for your very vintage CPU, this FreeBSD forum thread suggests setting a loader tunable for better OS compatibility:
hint.acpi_throttle.0.disabled="1"
ThomasTaylor
My Hardware:
FreeNAS Verison FreeNAS-11.3-U3.2
AMD Athlon(tm) II X4 640 Processor
DDR3 8GB i dont know witch one sry
1 TB HD as Boot
3x 2 TB for Data
Samuel Tai
Still need a bit more info. Motherboard model? Drive models?
Samuel Tai
Thank you. If the motherboard has a similar implementation of Cool 'n Quiet as newer Ryzen boards, then the path to stability found on later boards, and which may also apply to earlier boards, is to:
  • Disable Cool 'n Quiet in the BIOS
  • Disable CPU C-states, especially C-6.
ThomasTaylor
It looks good i givea report to you, tahnk you for your help.
