Today, I upgraded my server from 11.2-U7 to 11.3-U1.
After the upgrade, I realized that the previous versions is not working from Windows 10 client.
Here are symptoms(?) I observed:
- after restarting smb, I can see several previous versions from Windows client, but a few seconds later they disappear.
- When I tried to open previous versions (really quickly), it opens. However, when I try to open a specific folder or file, an error says it does not exist.
- From WEB GUI, I can access to snapshots and rollback older versions.
I checked threads in the community, and I found a similar problem, but it could not solve my issue.
I thought this is caused by ACL, and I created new pool(TEST), new dataset(001_TEST), and new samba share with default setting. Still, the problem is not solved.
Here is my testparm.
I would greatly appreciate it if you would help my problem.
# Global parameters
[global]
aio max threads = 2
bind interfaces only = Yes
disable spoolss = Yes
dns proxy = No
enable web service discovery = Yes
kernel change notify = No
load printers = No
logging = file
max log size = 51200
restrict anonymous = 2
server min protocol = SMB2_02
server role = standalone server
unix extensions = No
username map = /usr/local/etc/smbusername.map
username map cache time = 60
idmap config * : backend = tdb
allocation roundup size = 0
directory name cache size = 0
dos filemode = Yes
hide unreadable = Yes
include = /usr/local/etc/smb4_share.conf
[999_TEST]
access based share enum = Yes
aio write size = 0
ea support = No
hide dot files = No
mangled names = illegal
path = /mnt/TEST/001_TEST
read only = No
vfs objects = shadow_copy_zfs ixnas streams_xattr
nfs4:acedup = merge
nfs4:chown = true
root@nas1[/var/log]# zfs list -t snap | grep 001_TEST TEST/001_TEST@manual-2020-04-05_08-24 81.4K - 128K - TEST/001_TEST@manual-2020-04-05_08-37 81.4K - 128K - root@nas1[/var/log]# zfs list -t snap -o name,used | grep 001_TEST TEST/001_TEST@manual-2020-04-05_08-24 81.4K TEST/001_TEST@manual-2020-04-05_08-37 81.4K
