I have a fresh install of TrueNAS-12.0-U5.1.
First off let me say I'm a complete newbie and if there is a plugin I can use to do this better I'm all ears.
I have a "Video" dataset that is shared on my local network, and also moulted to my plex jail without issue.
I want to be able to share this directory remotely via sftp to a friend using read only access.
I have created a jail mounting video to a folder /SHARE within the jail, and created a user in the jail called "mark"
I have made the home directory of this user the /SHARE solder.
I can connect to the sftp server no problem but it cannot read the directory listing.
Similarly find if I use putty to ssh to the server the 'ls' command fails, but if I "cd .." to the parent directory 'ls' works as expected.
ls works fine when I'm logged on to the jail as root.
Can anyone suggest how/where the permissions need fixing?
please note im not well versed in linux etc.
thanks.
thanks.
