In FreeNAS 8.2.0, we got scheduled scrub jobs. (Yes! Thanks!)
My FreeNAS box hasn't been up for 35 days after I upgraded, but I couldn't help noticing that the crontab entry for the default scrub job looks wrong:
I don't think specifying months in hexadecimal is going to work.
This is on
I searched the bug report page, but didn't find anything about this problem there.
I hope this helps.
[root@kg-f3] ~# cat /etc/crontab | grep scrub 00 00 * 1,2,3,4,5,6,7,8,9,a,b,c 7 root PATH="/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/root/bin" /usr/local/sbin/scrub -t 35 zstore
This is on
[root@kg-f3] ~# cat /etc/version FreeNAS-8.2.0-RELEASE-p1-x64 (r11950) [root@kg-f3] ~# uname -a FreeBSD kg-f3.kg4.no 8.2-RELEASE-p9 FreeBSD 8.2-RELEASE-p9 #0: Thu Jul 19 12:39:10 PDT 2012 root@build.ixsystems.com:/build/home/jpaetzel/8.2.0/os-base/amd64/build/home/jpaetzel/8.2.0/FreeBSD/src/sys/FREENAS.amd64 amd64
I hope this helps.
